CD/DVD player advice
tcrossma
tcrossma Posts: 1,301
edited June 2007 in Electronics
Good afternoon everyone,
I need a little help understanding a few things about how my DVD player affects the sound in my system.
My receiver is a Yamaha RX-V2500 and my DVD player is a Toshiba that I paid about $200 for a couple years ago. I have the DVD player connected to the receiver using a Coax connection. I am using the DVD player to also play my CD's.
I've no real complaints with the sound quality, but am I missing out by not having something better? Is the DVD player affecting the sound quality, or because it is hooked up with a digital out is the receiver doing all the sound processing? Will upgrading the DVD player help me in any way? Should I have a dedicated CD player?
My speakers are T90e (Monitor 60) fronts, Monitor 30 surrounds, and an RM202 center.
Thanks for the help,
tim
Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH
Post edited by tcrossma on
  • steveinaz
    steveinaz Posts: 19,546
    edited June 2007
    Given your current set-up I would say you're fine using the Tosh DVD. Maybe down the road if you get into seperates you might want a dedicated CDP.
  • tcrossma
    edited June 2007
    Thanks, i'll stick with my same DVD player for now then.
