Wireless for 7.1 System?
reubenray
reubenray Posts: 91
Are there any wireless speakers that will work for side surrounds for a 7.1 system? There are some blu-rays coming out now that has 7.1 and would like to complete my speaker setup. But I cannot setup up the side speakers without running speaker wires across the floor. This will not pass WAF.
My signature shows what I have now.
Onkyo TX-NR709 A/V Receiver
Polk RTi8's Front
In-Walls for Rears
CSi5 Center
SVS 20-39PCI Subwoofer
Post edited by reubenray on
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited June 2007
    Sweet talk the wife. Wireless right now will be very disappointing.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • reubenray
    reubenray Posts: 91
    edited June 2007
    She will probably be OK with it, but I have hide the wires someway.
    Polk RTi8's Front
    In-Walls for Rears
    CSi5 Center
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited June 2007
    You can buy the flat wire and run it around the perimeter, up and over entry ways, see if you can use the base trim boards to hide it a bit, if you have crown molding you can it behind those. Just depends how much work you want to put into it.
    Have fun and enjoy.
    RT1
  • honda cber
    honda cber Posts: 267
    edited June 2007
    samsung has a wireless surround system (i saw it at sams club yesterday), so it is definitely possible... quite a bit less hi-fi than your RTi8's, i would guess. a good friend/former housemate had a pair of wireless speakers some time ago (pretty sure they were AR)... nothing to wow you, but they performed reasonably well... i think they were IR, though, so line-of-sight will be important, just like your remotes. there is technology that uses your house wiring to transmit as well, but i am not sure who makes what, or if the sq is anything above "works"...
    cant you go through the attic or basement/crawl?
    a
    gear list:
    1 down, 4 up....
  • joeparaski
    joeparaski Posts: 1,865
    edited June 2007
    Keep in mind that wireless speakers aren't really wireless....they still have a power cord attached to them that you need to plug into the wall.
    Joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • Ricardo
    Ricardo Posts: 10,636
    edited June 2007
    And it needs to be a thick/cool looking power cord if you want great sound.
    SOPA
  • seeclear
    seeclear Posts: 1,244
    edited June 2007
    If you have carpet in the room, try to see if you could push the wire in under the base edge of the base moulding. It might take a little bit of effort, but once you get it started, it goes in a lot easier. I just did this in our downstairs, where we have carpet stretched over slab concrete. It might even work with a "floating" style hardwood or pergo floor, as that (may) have a spongy pad under it that would allow some 'give'.
    FWIW
    :D:D:D:D
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • joeparaski
    edited June 2007
    Waaaaaaaaaaaaaa.....good one Ricardo!!!!
    joe
