which speaker to add for 6.1
First off,this is my first post. I have a CS-245i center, Rt-55i's for my front's, Rt-35i's for my surrounds,and a JBL DPS-10 Sub. I've got a couple questions and am not sure if it's proper to post them both here or ?? but Here goes.
I'm planning on upgrading to 6.1 and am wondering which would be the best rear speaker to add. My space is 11.5' wide X 14.5' long. I've got 2 bookshelves about 1 foot behind my seating area as well as wall space above that to mount . Bookshelf space is 12" and 24" above my seating and is 9.5" deep and 11.5" high. Above that is 1' of wall space before the cieling. I'm wide open on suggestions for that speaker.
I'm also planning on getting a new TV a. I'm down to a Panasonic CT-32HX42 or a Sony KV32-HV600. While I'm not locked in stone on the TV's,they seem to be the best I've seen for my price range(up to $2,000) and prefer direct view.
If I shouldn''t be mixing the TV's in this forum,sorry.Please let me know where I should post otherwise.Any and all suggestions are greatly appreciated.
Brentski
Brentski
Center; CS-400i
Main's; RT-55's
Side Surround's-RT-35's
Rear center;CS-300
Sub; SVS PB12-NSD
Main's; RT-55's
Rear center;CS-300
Sub; SVS PB12-NSD
Post edited by brentski on
Add another CS245i for your rear center. Or even better find a CS400i for your front (it is a perfect match for the RT55i and RT35i) and move your CS245i to the back.
I would step up to a 36"(size does matter). There are several good ones out there in your price range."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
And for 2 grand you can do alot better than a 32" tv.;)
Think big. -
So move the 245 to the back and get a CS400 for the front? That I can do and it will fit(plenty of room in the length and heigth but will the it get muffled in the bookcase with it's power port as it will be right up against the back?).
As far as the TV,Which sets are recommended for my $2000 range. Anyone have experience with sets I should consider?
I've seen some 'real low' prices on Reliable Home Theatre. Any knowledge of this here or should I stick with a local dealers for a TV ?
Thanks again,brentskiCenter; CS-400i
Main's; RT-55's
Rear center;CS-300
Sub; SVS PB12-NSD -
the sony kv365hs500 is 1999 @ Circuit City. Right now you can get a $100 gift card with the TV so they charge 1899 give you 100 that you can use for thier esp or cables. offer ends today.
I'm planning on making the same move as you (6.1) and i plan on moving my csi30 to the rear and getting the csi40 for the front.Pioneer Elite VSX-21TXH
Monolith 7x200 Amplifier
Harmony Hub
Sony VLP-HW40ES
Visualapex 106" Electric Screen
Oppo BDP-103
Music Hall MMF 2.1
Polk LSiM 705
Polk LSiM704c
Polk LSiM702F/X
SVS PB-2000 -
Muahahaha, Im going to do the same as yall. I am going to sale my yamaha receiver, and get another Yammer with 6.1 and 6.1 perouts. I will Just get a Csi30 for either the front or the back. Depends how It all rolls. I would get the i40, but then i'll have to upgrade da mains too, and I dont have that cash, and if I do I need a new vcr and DVD Player.Damn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC -
Called my local Polk dealer and mentioned to him what 's been suggested here.Taking my current center(CS-245) and using it for my new rear speaker along with my current surrounds(RT-35's) and replacing my center w/a CS-400.He said that speaker(245) wouldn't fit the bill or sound right as my rear spkr,instead,suggesting I get another RT-35 for that. Is he nut's or just doesn't know what he's talking about?
Question.is the new CSi40 matched close enough to add to my RT-55 fronts or should I search for an old CS400?
Also,what other TV's should I compare to the suggested KV-36HS500, streaching my TV allowance to about $2,300. Stay with Sony or????
Again,thanks for the suggestions,BrentskiCenter; CS-400i
Main's; RT-55's
Rear center;CS-300
Sub; SVS PB12-NSD -
Different people WILL suggest different things.
Yes another rt35 would be perfect for the rear - let me know when you get a single rt35 or pay more for the pair than the cs245. Like I said I have the cs245i along with my fx500i's and it sounds very good. Either will do well. Even better by 2 cs400's one up front and one in the rear. Options are there.;) -
would the CSi40 have the same "voice match" to go with my older the Rt-55's and 35's? Everyone says to stick with the same brand and model,but am wondering if the CSi-40 would provide the same 'seamless' sound match as the CS-400 would?Center; CS-400i
Main's; RT-55's
Rear center;CS-300
Sub; SVS PB12-NSD -
Seamless - I would say no. Different tweeter and design.
