blown fuse
Systems
Systems Posts: 14,872
edited January 2003 in Car Subwoofer Talk
can somone tell me why my amp fuse kept burning out on me? i install a new wiring system from that day on everytime i insert the fuse into the fuse holder, it got blown up. wat can i do to correcdt his source of error.
thanks
Testing
Testing
Testing
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited January 2003
    if the fuse is blowing before you even turn the system on, then you have a bad short somewhere... trace your lines for kinks, screw punctures, etc etc.
    if the fuse is blowing once you turn on system on, you need to determine---
    1- if its the proper size fuse
    2- if the amp is damaged (or or other components on that line)
    3- if any capacitor you might have is damaged.
    The Artist formerly known as PoweredByDodge
  • Systems
    edited January 2003
    i tried it with a different amp , same brand with lower wattage, and it works find, but the other ones, the fuse burn before the system is turned on. that means it is not the wiring problem and its is not the amp problem according the the previous threat becuse the system is not turn on.
    i really need an answert to this question, thanks
    tdo
    Testing
    Testing
    Testing
