Using an RX-v2600's A/B zones to bi-amp?
jlcool007
jlcool007 Posts: 3
Well, i Recently just got a pair of rti10's and my rxv2600 receiver in also.
I need to know if it is OK to bi-amp the speakers using the selectable a-b (speakers)(both can be on btw).
My amp was rated at 122wpc (constant) all channels driven by audioholics. So, in theory, i would be sending my speaker's 244w each.
is this possible?...here is a pic of the back-side of the receiver:
http://www.crutchfield.com/S-DUpTq3bZczy/cgi-bin/ProdView.asp?g=10420&tab=morephotos&pi=2&i=022rxv2600&display=XL#Tab
-jl
Post edited by jlcool007 on
  • jlcool007
    jlcool007 Posts: 3
    edited June 2007
    ....double post
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited June 2007
    If you use A and B you will not get any more power, they are both running off the same two amp channels, tied together inside the reciever.
    And it won't work with zone two either, as the volume control for main and Zone two or three are independent.
  • jlcool007
    jlcool007 Posts: 3
    edited June 2007
  • VXR8
    VXR8 Posts: 291
    edited June 2007
    If you go to page 19 of your user guide, you can bi-amp the RTi10s (as I have done with my RX-V2700 and RTi10s). You use the "Front" left and right set of speakers outputs for lets say the bottom posts on the 10s and use the "Surround Back" terminals on the Yammie for the top posts on the 10s. There is a diagram on this page showing you how to do it. You'll also need to remove the binding posts on the speakers as well.
    Link for the user manual - http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V2600e.pdf
    Hope this helps.
    Regards - Gaz from the land of Oz
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    Cambridge Audio - Azur 851C - CXUHD
    Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
    SVS - PB1000 x 2
    Foxtel - iQ4
    Belkin - Pure AV PF40
    Sony K77A9G
    Front Room System
    PS Audio - Sprout 100
    Cambridge Audio - CXC S2 - CA752BD
    Sony - UBX800 4K BluRay
    Polk Audio - Legend L200
