Amp for rti8's
PolkFan1
PolkFan1 Posts: 130
edited June 2007 in Speakers
What would be a good mid priced amp for my rti8's?I only listen to music and currently have a psw12 sub and an hk3480 harmon kardon receiver.
Post edited by PolkFan1 on
  • ben62670
    ben62670 Posts: 15,969
    edited June 2007
    Adcom GFA-555. There were a ton made, and can be had cheap on ebay, and audiogon. They have large toridal power suplies, and large caps in them. They are very tight, and musical. How much are you looking to spend?
    http://www.adcom.com/manuals.aspx
    A little higher up is Parasound, Rotel, and ......
    Ben
  • PolkFan1
    PolkFan1 Posts: 130
    edited June 2007
    like $250 ish. If I spent more am I really going to get more? Is there going to be any significant difference in just buying the one you posted?
  • ben62670
    edited June 2007
    PolkFan1 wrote: »
    like $250 ish. If I spent more am I really going to get more? Is there going to be any significant difference in just buying a 250 dollar amp?
    It depends on your ears. I have made many purchases over the last year, and have regretted not doing it right the first time. 250 really limits your options. Don't rely to heavily on watts. Its currant that makes the big difference. Your HK should be doing a decent job of driving your speakers, so if you are looking to upgrade I expect that you have critical ears. Take your time, and do it right. A deal will pop up.;)
    Ben
  • Willow
    Willow Posts: 11,218
    edited June 2007
    I say look for some outlaw's mono. They can be found cheap. I am using one on my csi3 and using Marantz MA700 monos for my rti8s. It's a big difference.
  • engtaz
    engtaz Posts: 7,669
    edited June 2007
    Adcom,Outlaw Audio are very good. Take time to check out all your options. Read thru the threads to get others opions. Topic has been covered about amps numerous times.
    engtaz
