DAC Help . . .
SolidSqual
SolidSqual Posts: 5,218
edited June 2007 in Electronics
Can anyone recommend a nice DAC in the $200-$300 range used or new?
Post edited by SolidSqual on
  • crossroads
    crossroads Posts: 32
    edited June 2007
    You can get a nice EAD ( Enlightened Audio Design ) DSP-7000, Monarchy, Channel Island or a NOS ( None Over-Sampling ) DAC for that price. Good luck.
  • AndyGwis
    AndyGwis Posts: 3,655
    edited June 2007
    I have a Theta Pro Progeny (bought Agon for $300) that I like. I think you can get Theta Pro Basics for around $300 as well.
    Should also be some options from Musical Fidelity in that range.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • tryrrthg
    tryrrthg Posts: 1,896
    edited June 2007
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited June 2007
    tryrrthg wrote: »
    I take it that's a NON-OS Dac? Pony up some details, if you'd be so kind:)
  • tryrrthg
    edited June 2007
    Yep, NON-OS DAC. I don't know a lot about it, never even heard it, I've just seen a lot of satisfied people at audiogon that have. for the money it would be worth a try...
    I still think one of you (Zombie or SolidSqual) should buy my Arcam CD73. :D
  • zombie boy 2000
    edited June 2007
    Once enough funds get cleared, either this or the Bada will be in the batter's box:) I haven't forgotten ya.
  • Lowell_M
    Lowell_M Posts: 1,660
    edited June 2007
    ADCOM GDA-600 or -700. ~$230 on ebay. There was one on Audiogon that may still be there.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
    heiney9 Posts: 25,431
    edited June 2007
    +1 for Monarchy.
    You get a lot of bang for your buck buying a used Moarchy dac. Of course the newer gens are a little bit better but not usually worth the extra cost
    For example a 22A goes for between $200-300 and the 22C goes between $500-700 and there isn't a $300 to $400 difference in sound unless you are using other really great complimentary components.
    YMMV
  • zombie boy 2000
    edited June 2007
    And the 18b can usually be had for around $185 -- with a built-in preamp to boot.
    edited June 2007
    a_mattison wrote: »
    especially the 600. It has a very magical sound, everything so just sounds so good thru it. It's not your typical Adcom "house" sound, they did something right with this unit, can't put my finger on it, but it just sounds so good.
    The 700 has HDCD but I'm told the 2 designs are slightly different and many prefer the PCM 63 Burr Brown chips in the 600 over the PCM 1702 Burr Brown chips in the 700. The difference is very slight and for some less critical listeners non-existent.
    Another sleeper is the Aragon D2A and D2A2.
    edited June 2007
    Passive line stage pre amp section.
  • rskarvan
    rskarvan Posts: 2,374
    edited June 2007
    heiney9 wrote: »
    I purchased the ADCOM 700 DAC because it uses the PCM1702 chips. These are the same chips that are used in the Krell KAV300CD. So, I'm thinking if its good enough for Krell... its good enough for me.
    edited June 2007
    rskarvan wrote: »
    I wholeheartedly agree, but I was specifically talking to one of the techs who originally worked at Adcom in New Jersey and he was telling me a bit about the 600 and 700 and their differences.
    The BB PCM 1702 chipset has to be used if you are using the Pacific Micronics HDCD filter. You can't get HDCD using the older PCM63. In fact many designers still pefer the PCM63 to the newer PCM1702 as a matter of choice. Even Monarchy still uses the PCM63 in their latest dac the M24 which uses tubes for the dac output as well as a seperate tube section for the line stage preamp.
    Bottom line is they are both excellent chipsets and if it's good enough for Krell than it's pretty damn good :)
