Started my new custom SDA's today
1235713
  • Systems
    Systems Posts: 14,873
    edited June 2007
    Isn't DIY fun.
    After that much work you deserve a rest.
    Testing
    Testing
    Testing
    heiney9 Posts: 25,398
    edited June 2007
    Get back to work!!!:mad:
  • engtaz
    engtaz Posts: 7,669
    edited June 2007
    Too funny slave drivers? LOL
    engtaz
  • Mazeroth
    Mazeroth Posts: 1,585
    edited June 2007
    Which brand/model of drivers are you using. I'm a seasoned speaker builder myself and thought about buliding a pair of cheaper SDAs for kicks. With over 500 drivers in my basement it wouldn't be a problem :D
  • ben62670
    ben62670 Posts: 15,969
    edited June 2007
    Mazeroth wrote: »
    I am using all Polk MW woofers, and Morel tweeters. Polk still have the MW's, and with an fz of 29-31 they are the best, clearest, most efficient speakers around. I looked for something cheaper, and better. No dice. It is definitely worth building them. Have you ever heard SDA's before?
    Ben
    Ben
  • ben62670
    edited June 2007
    Well I am working on my SDA control box seeing my back still hurts from yesterday, and last night. It has 3 inputs, and six outs. 2 outs are going to be SDA/subs, 2 will be stereo, and 2 will be the highs. The center nob is a fader for bias between the Dim's, and the Stereo's. I will finish installing the level control for the highs later.
    Ben
  • Mazeroth
    edited June 2007
    ben62670 wrote: »
    Ben
    Fs doesn't attribute to the clarity or efficiency of the speaker, just the resonant frequency of the driver. The higher the moving mass of the driver, the lower the Fs. When moving mass goes up, efficiency drops. Anywho. Did you test any other drivers out before picking the MW? Also, what was the damage on those guys and which Morel did you end up going with?
    I had a chance to listen to a few SDAs in my days. Very nice sounding speakers with crazy imaging. I built a pair of line arrays two years ago and just recently got rid of them, making room for my next pair of line arrays. Here's a thread of my build:
    http://www.polkaudio.com/forums/showthread.php?t=27913
    I'm currently listening to a pair of 3-way dipole speakers I'm building that sound too good to be true. Check them out here:
    http://www.htguide.com/forum/showthread.php4?t=24590
    Keep us posted with your progress! Good work so far!
  • ben62670
    edited June 2007
    Wow. Very nice looking line arrays. I tried some EOS one drivers, and a couple of the cheaper dayton paper cones. I drove them electronically crossed over with a tweet. I liked the Polk's the most for vocals, and bass slam. The Morels I chose are the MDT20's. I am doing passive inline crossovers before the amp, and I was thinking about doing a L/R 12db to keep the phase correct on the tweets for 24db total. I do not know for sure how I am going to wire the tweets yet. I think there will be some trial, and error involved with those;)
    Keep up the good work!
    Ben
    Ben
  • ben62670
    edited June 2007
    Well today I am starting the speaker wiring harnesses. I have over 80 fast on connectors to crimp:(
    Ben
  • hearingimpared
    hearingimpared Posts: 21,136
    edited June 2007
    ben62670 wrote: »
    When you wake up tomorrow your hands are going to look like claws!
  • jcaut
    jcaut Posts: 1,849
    edited June 2007
    Man, you've gotta be pretty dedicated to take on this project. I like building speakers, but I hate building cabinets.
    I didn't read through all 5 pages so I apologize if you've already been asked this. How are you deriving the SDA signal?
    Jason
  • ben62670
    edited June 2007
    jcaut wrote: »
    Jason
    I was thinking of trying it 2 ways, and see what is best. The first way. Seeing that the dims are on their own circuit with no caps, or inductors for the crossover I was thinking about running the hot straight out of the amp into the positive of they dim array. From inside of the cabinet running the negative out of the cabinet to the negative in the other cabinet. So both hots are connected to the amp. Both grounds are connected to each other. OK now I don't have the ground connected to the amp. In the center of the speaker cable (read single custom speaker cable) ground I was thinking of attaching an 8mh inductor(1.2TL's use 16mh per cab. Inductors are like resistors value drops in half when Parallel). One side of the inductor is connected speaker cable ground, and the other side of the inductor is connected to both sides of the amp ground. Circuit complete.:) Second way Blade blade caps, and inductors like SDA-SRS. :cool:
    Ben
  • hearingimpared
    edited June 2007
    ben62670 wrote: »
    Who's on first;
    What's on second;
    I dunno's on third!!!:D :p
    edited June 2007
    Ben I applaud your effort and thinking, but you seem to have taken a fairly complex idea (Stereo Dimensional Array) and simplified it. I can’t imagine it working at all like Polk originally executed it. They had all sorts of phase correction, signal correction and compensation built into the x-overs. Even the cascaded taper array of the tweets was a complicated effort to keep refraction, lobing and off axis response acceptable. How are you compensating for phase issues and lobing issues and on/off axis response, etc. How are you going to make sure the multiple tweets play smoothly and are a true point source? Frequency response is but one small part of making a speaker an enjoyable top performing experience.
    Please take this as constructive criticism and not as a knock on your project.
  • ben62670
    edited June 2007
    Well I have been thinking about the home theater thing, and the glare issues with the speakers next to the screen. I think I am going to go the original SDA route with the wood trim, and the grill cloth on the sides.;) :) :cool:
    Ben
  • ben62670
    edited June 2007
    heiney9 wrote: »
    I hear you on that, and have done a lot of studying of line arrays, and phase issues. I think you missed an earlier post where I am going to send the high frequencies from the amps to the cabs. I will actually be adding a crossover section within the cabs for the tweets to
    A: increase the slope to 24db
    B: correct phase problems with higher frequencies.
    I have studied many Polk SDA XO's, and will be cutting the higher frequencies to the outer, or upper tweets. This will take time to get right. I would love it to just work the first time, but I do fully understand the complex issues with the tweeter arrangement. The XO will be mounted outside the cabinet till I get it right!
    Thanks H9;)
    Ben
  • ben62670
    edited June 2007
    Well I am finally posting a pic of the wiring harnesses for the MWs. 72 crimp ons total. :)
    Ben
  • ben62670
    edited June 2007
    The last of my drivers will be here tomorrow! I should be up and running this weekend. I finally stopped wasting time on ebay, and went straight through Polk.
    Ben
  • ben62670
    edited June 2007
    Drivers, drivers, and more drivers.:D :D:D
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited June 2007
    LOL...Open you own Polk parts store Ben.
    I'll take 2 mw6500's and 2 mw6510's...lol
    The CS at the Polk store must have wonderd what the hell you needed all those drivers for...lol
    Very nice speakers.
    Poor sonotube. What did you do to it???:mad: :mad: I'm crying..:( :(
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • ben62670
    edited June 2007
    jakelm wrote: »
    Very nice speakers.
    I neutered it.:D
    I feel like less of a man with it like that.:o Now if I started with a 5 footer it would be cool. I hated to shrink it.:(
    Ben
  • engtaz
    engtaz Posts: 7,669
    edited June 2007
    ben62670 wrote: »
    I neutered it.:D
    Hey you said you were not going to take pictures of the sub. LOL
    engtaz
  • jakelm
    jakelm Posts: 4,081
    edited June 2007
    ben62670 wrote: »
    I neutered it.:D
    Made a mountain into a mole hill.
    You said it was 4' tall with a 15" Dayton in it? It still must sound very good. But is that enough airspace for the 15"?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    edited June 2007
    engtaz wrote: »
    I lied:p
    Ben
  • engtaz
    engtaz Posts: 7,669
    edited June 2007
    You having too much fun. Well well How do they sound. I know you waiting to break them in but what are the intial thoughts.
    engtaz
  • ben62670
    edited June 2007
    jakelm wrote: »
    With the end caps it is almost 5 feet. I have a hard time saying its less that 5 feet tall:o
    I just counted up all my mw's not in use, and I have 43. 32 for this, 8 for SDA1 C's, and only 3 left. I need more drivers for my center. I was thinking an 8 MW center, but how much do I really need. 4 MW's is plenty to keep up with any movie listening, and really don't think these are going to be much louder than the towers I have now. My first experiment used 4 MW's, and 2 10" PR's and they hit 120db. They were louder than the SRS copies I have now by 2 or 3db, but did not have the full open sound stage that I have now. I am very excited to get these together this week. Maybe a test drive this Sunday?
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited June 2007
    Where are the finished pics??
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • agfrost
    agfrost Posts: 2,460
    edited June 2007
    Much respect to you, Ben. I couldn't dream up such a project, let alone bring it to reality.
    Hope they sound as impressive as they look!
    Jay
    Jay
  • ben62670
    edited June 2007
    jakelm wrote: »
    I'm not done yet. I just got the drivers today. I ran out of money to "finish" the cabs, but they will be operational soon. I'll post pics and thought after I fire them up. Take a quick peak at this. Page three is what I am all about.
    http://www.audiodiycentral.com/resource/pdf/nflawp.pdf
    Ben
  • ben62670
    edited June 2007
    agfrost wrote: »
    Jay
    Thanks Jay. I definitely appreciate it. I have spent a lot of time researching this project. The research has take so much more time than the actual work!
    Ben
