Radio Removal on 2002 Jaguar Type S?
Polkemon
Polkemon Posts: 144
I have hit a brick wall on finding anyhting on the how to remove the radio and door speakers so I am hoping that someone here has the answer.
NEWEST RIDE:
2006 Silver Jaguar XKR Coupe with factory BBS 20" and upgraded Brembo Brakes from factory....
Supercharger Pully Upgrade
Air Intake
Mina Exhaust System....
2007 Chevy Tahoe (Daily Driver):
Front Doors POLK sr6500
Amp front JL 450/4
Amp Sub JL 500/1
Sub JL 10w6
(Work Trucks)
2005 Mercury Mountaineer Premier 4.6L V-8
All Stock!!! In the process of changing this.
2002 Chevy Silverado 2500HD 4x4 Crew Cab 6.6L Diesel
Post edited by Polkemon on
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2007
    Hammer and Screwdriver.
    heiney9 Posts: 25,412
    edited June 2007
    Jig saw's work nicely as well. They make the job go quickly, but re-installation of new pieces is a bit more work unless you don't mind and unsightly mess.
  • engtaz
    engtaz Posts: 7,669
    edited June 2007
    Car audio is a better place to post.
    engtaz
  • Polkemon
    Polkemon Posts: 144
    edited June 2007
    I thought people would take real questions a little more seriosly than this.
    NEWEST RIDE:
    Air Intake
    Amp front JL 450/4
    Amp Sub JL 500/1
    Sub JL 10w6
    (Work Trucks)
    edited June 2007
    Sorry, but you should post in the car audio forum and you will get some responses. Although if no one has actually worked on a Jag you may not. Good luck.
  • Pablo
    Pablo Posts: 723
    edited June 2007
    From my experience here, you ussually do get good answers. But once the jokes start, sometimes they go on and on.
    Did you get you get anything done yet? I don't know anything about the jags, so I probably won't be able to help. As far as the door speakers, I'm sure you'll have to remove the door pannels. They're ussually not held on by more than a couple of screws in the door handle.
    Let me know how it goes, and good luck.
    Denon AVR-3803
    RTi-70 Fronts
    FXi-30 Surrounds
    RTi-38 Back Surrounds
    Csi-40 Center
    PSW350 Sub
    Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
    Denon DVD-2910
    Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64
