Running cable behind drywall
Serendipity
Hi,
I'm currently working on my basement and wonder what is the best way to run cables behind drywall? I also have a drop ceiling and want to run speaker cable, HDMI, VGA, composite, S-video, Cat5, and telephone cable inside the ceiling.
So - what tools are best for getting wire through tight spaces and what's the best way to route wire through walls?
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
Fish tape and WD40.
CL rated cables and wires, check monoprice.com
Use a fish wire/tape tool which is available at Lowes/Home Depot
Prepare for significant exasperation...Monitor Audio GR 60, GR10, GRLCR
Velodyne HGS18
Emotiva MMC-1
Parasound Model 5250
Denon DVD-3800
Pioneer pdp-5070
Secondary HT with B&W CDM-NTs all around and Rotel Separates (thanks Venom!) -
Hi,
See the link. I used the 12Ga. Belden 5000 and am very happy with it. It pulled nicely through the walls (and is meant for it). If you are down to the studs, run the speaker cable the same as you would electrical....drill holes in the studs.
http://www.bluejeanscable.com/store/speaker/index.htm
Edit: After re-reading your post, it sounds like you already have drywall up.... In that case....that's going to suck, man!HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables -
what they said^^^^
I don't know what you have in mind?
I would run everything in the ceiling(since it's a drop), and try to locate the studs of the wall from the ceiling (run the wires between studs) or maybe even use a stud finder(never had luck with them) and then drill a small hole in the approximate area of the drywall where the wire would come out. Use the fish tape through the drywall and try to catch it up above in the ceiling(attach speaker wire or whatever you are doing with electrical tape, a second person is helpful). Lube up the wire first with some WD40 and pull it through. The WD will act as a slight lubricant making the wire easier to pull, and less chances of making any tears or cuts in it.
Good luck.
Mike -
Where is our forum electrician?? (kolyan2k)
I'm sure he has a better way.;) -
:rolleyes: Mike, What about a pressure washer? Worked for the plumbing. heh heh heh...:oHT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
a_mattison wrote: »:rolleyes: Mike, What about a pressure washer? Worked for the plumbing. heh heh heh...:o
Yeah, F*CK YOU!:D -
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
u said it. just don't really need WD40. and avoid fluorescent lights, if u have any.
