Started my new custom SDA's today
2456713
  • ben62670
    ben62670 Posts: 15,969
    edited May 2007
    Lasareath wrote: »
    Hey Ben, Looking really good so far!, I'm trying black Lacquer on my side panels instead of grille material and it's turning out to be a royal ****.
    I may just bring the original side panels to an upholstery shop and have them put new material on them.
    Are you going to glue the cabinet together like Polk does?
    Sal
    I am using liquid nails on all joints, and then caulking them with it. Also tons of counter sunk screws!
    Ben
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2007
    The Nutty Professor! I think you might look like the guy in the old Memorex commercial when you first fire them up!
  • ben62670
    edited May 2007
    I have also heard back to the future when MJF hit the guitar! :D
    Ben
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited May 2007
    Tell me you are going to do some more bracing than that (as shown in the pics), for the finished product. You need a least a half dozen dado style down the length of that box.
    Please don't load all those drivers without additional bracing, the box is surely going to flex with current setup.
    I applaud the effort, I really do. Do you guys/gals not realize that engineers spent countless hours designing these things? Charts, graphs, anechoic chambers, slide rules, silly putty? To think one can 'throw together' a pair of SDA is unfathomable for me. How did you determine the box size, mass, and tuning of the passive radiators?
    Honestly, I hope you are successful, I really do. On the surface, all I see is a Frankenpolk, and lot of wasted effort (and sought after SDA parts). Get a grip on SDA, and reality for that matter. Keep us posted as to the progress.
    Cheers,
    Russ
  • ben62670
    edited May 2007
    RuSsMaN wrote: »
    Cheers,
    Russ
    Its braced even though there is no span greater than 14.5 inches:)
    I am also going to treat the interior with asphalt based sound deadening material before the poly mats.
    Edit
    I made that mistake on my first experimental. If I put my head against the box my eyes went screwy.
    Ben
  • WolfKiyoshi
    WolfKiyoshi Posts: 96
    edited May 2007
    Back To The Future reference works perfectly Ben :) by the way i suggest moving out to the country.. because those speakers may possibly piss off people within a 10 mile radius ;)
  • hearingimpared
    edited May 2007
    And level land cause those babes will cause earthquakes.
  • ben62670
    edited May 2007
    I'm in Fort Lauderdale. The only thing they will worry about is them starting hurricane. Hey I think I'll play Scorpion's "rock you like a hurricane next scare" :)
    Ben
  • WolfKiyoshi
    edited May 2007
    play Iron Man by Black Sabbath through them :) kind of a "waking the beast" type sound to me :D plus it'll just sound awesome lol
    heiney9 Posts: 25,440
    edited May 2007
    So, do you have to stack a few phone books under a tall bar stool to be in the sweet spot? Maybe you are 7 1/2 feet tall? :confused: :eek: .
    Good luck Ben :)
  • ben62670
    edited May 2007
    heiney9 wrote: »
    Good luck Ben :)
    Actually the middle of the array is right at where I wanted it for seating position. The center of the driver array is about six inches higher than my ears on the sofa. When you are at a concert the stage is almost always a little higher when you have good seats, and also movies. I did A LOT OF PLANING before starting this project... A LOT.
    As far as progress for today, everything is working great so far.
    "I just love it when a plan comes together" (A Team)
    Ben
  • ben62670
    edited May 2007
    RuSsMaN wrote: »
    Cheers,
    Russ
    I just wanted to add a little onto Russman's post. MDF is very flexible. I do strongly advise real bracing in a project like this. A good example is on one of my boxes one of the long pieces had a 3/16" gap. While using a screw gun I pulled that MDF without a problem. This stuff is very flexible!
    Ben
  • Systems
    Systems Posts: 14,873
    edited May 2007
    Wow Ben that is a very ambitious project.May I ask why you didn't just use active crossovers instead of the inline passives?
    Testing
    Testing
    Testing
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    Active too easy LOL
    engtaz
  • ben62670
    edited May 2007
    GV#27 wrote: »
    I just bought an outlaw 990 pre. I have spent probably 60+ hours on studying active crossovers. The op-amps in the 990 are very dynamic, and clean. Almost all actives in my range are designed for Pro Audio with some pretty unappealing specs. I have also looked at using higher end auto crossovers. I have actually used them with my setup, and was quit happy with them. Nothing is set in stone right now except that I am not going to use the standard in the speaker crossover. The passive in lines do not require any power, and are very clean. I have used some in past experiments, and was very impressed.
    Edit
    I just finished building the second tower. Most of the holes are cut, and recessed for flush mounting.
    Ben
  • Systems
    edited May 2007
    If decide you want try the active route and you are into doing a little DIY electronics Marchand sells some excellent active crossover kits or just the PC boards that you can use your favourite opamp and resistors etc in. http://www.marchandelec.com/xm9.html
    Also the Behringer CX2310 is pro unit that while being inexpensive Ive heard of guys using it with excellent results in hi end systems.http://www.behringer.com/CX2310/index.cfm?lang=eng
    Testing
    Testing
    Testing
  • ben62670
    edited May 2007
    GV#27 wrote: »
    Thanks GV I have looked into both of those options. I am not ruling either of the two out. I have just decided to go passive at least for now. A lot has changed(especially with this project), and have had very pleasing results before with the passives. I will try active via 12v battery (no noise) also. it is a simple test. These will not be finalized for a long time! If ever!:D
    Thanks Ben
    Ben
  • Systems
    edited May 2007
    ben62670 wrote: »
    Thanks Ben
    Cool Ben,I will be watching with interest as your design progresses.:)
    Testing
    Testing
    Testing
  • ben62670
    edited May 2007
    Just some more pics. A fellow Polkie recommended that I put some tweeters in them so...:p Here they are.:)
    Ben
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    Fantastic work. Sure makes my back hurt.
    Great job Ben
    engtaz
  • ben62670
    edited May 2007
    engtaz wrote: »
    Great job Ben
    Thanks ET :D
    Ben
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited May 2007
    um....ah.....my back hurts. Looking good.
  • ben62670
    edited May 2007
    Oh yeah the center of the tweets are 53"s from the bottom, just right for my setup.
    Ben
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited May 2007
    ben62670 wrote: »
    Damn man,That's the first set of speakers I've seen that takes a forklift to move them around:D
  • ben62670
    edited May 2007
    I'm 6 foot, and over 200lbs. These things make me feel teeny tiny, and thin:)
    Edit 10' ceiling
    Ben
  • schwarcw
    schwarcw Posts: 7,358
    edited May 2007
    WOW!:eek:
    Nice work Ben!
    Carl
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited May 2007
    Big Stuff!!!!!!
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • Systems
    edited May 2007
    Nice work,I bet you had a truck full of MDF dust after building these.
    Testing
    Testing
    Testing
  • ben62670
    edited May 2007
    GV#27 wrote: »
    I started in the shop. I cleaned one edge with a flush cut bit on a router. It made a big mess. Loaded it on the fork truck, and went outside. It makes an incredible amount of dust. Mostly using the router with the plunge bit to do 20 holes per cab. I used a hole saw for the tweets. Do not attempt a project like this indoors!:eek:
    Ben
  • Sumbrada77
    Sumbrada77 Posts: 37
    edited May 2007
    Hey Ben great DIY you have going! No doubt they will be loud!!! Question for ya, I am redoing Monitor 10s crossovers (original series) and will be posting my work. What do you use to do the thumbnails to blow up pics?
    Thanks!
    CARPE CEREVISI!!
    A Wise man, Keeps his Friends close, but keeps his
    Enemies Closer !!
    Yamaha RX-V659 A/V receiver, Maganox CDP482 CD,
    Pansonic DVD F85, Marantz 6300 TT w/Apature KOCE
    Polk 10s (mains), M&K 3B (backs), Polk 5b Center
    HSU Research VTF-2 Mk1 subwoofer
    DIY twisted speaker cable
