Lights Dimming
Guys, I've got a question. How can I keep my lights from dimming when my subwoofer is hitting way down low during movies. I mean sometimes, like on the beginning train scene on "Unbreakable" the lights dim at least half way. Is there some way to help prevent this. See my system setup below, I'm running an SVS sub and I would think that the 900 watt BASH amp would take care of feeding the sub all the quick power it needs, but maybe I'm wrong.
Fronts: Rti 150s
Center: CSi 40
Side Surr: Rti 55
Surr. Back: Csi 30
Sub: SVS PB12 Plus/2
Receiver: Denon 3802
Conditioner: Monster HTS 3500
Post edited by loragland on
  • louthewiz
    louthewiz Posts: 581
    edited May 2007
    I used to have that same problem with my subs and amps until I ran a dedicated 20amp circuit for them...
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
  • PolkThug
    PolkThug Posts: 7,532
    edited May 2007
    I turn out all the lights when I watch movies.
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited May 2007
    Easiest way to fix it is to send me your svs, just pm me and I'll send you my address. Just kidding. Your best bet is to put it on a dedicated circuit, or put yous svs on a different circuit than your amps. Plug lights in to different plugs through out your room, and go flip your breakers off one at a time, If you get a light off, and one on in you listening room put your amps on one of the plugs, and the sub on the other.
    edited May 2007
    Maybe some kind of anti-audio evil spirits thing going on...:p
  • Strong Bad
    Strong Bad Posts: 4,278
    edited May 2007
    Some of us actually think thats cool when it happens. We brag to people about how our rigs dim the lights. :D
    No excuses!
  • Serendipity
    Serendipity Posts: 6,975
    edited May 2007
    Install a 20 amp dedicated circuit for the sub. I have one for my sub (1500W), projector, and air conditioner (2200W) so the lights don't dim when the projector is powered up or there is a peak in the music, etc.
    Most high-end home theaters need at least 2-3 dedicated circuits, more is better.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • loragland
    loragland Posts: 15
    edited May 2007
    Those are some great down to earth ideas fellas, thanks for the feedback.
    Fronts: Rti 150s
    Center: CSi 40
    Side Surr: Rti 55
    Surr. Back: Csi 30
  • goingganzo
    goingganzo Posts: 2,793
    edited May 2007
    turn down the volume or get a class d amp
    VR3 Posts: 29,534
    edited May 2007
    My lights dont dim.
    The filaments just vibrate out of place and back into place every microsecond.
