I'm torn between old stock tube warmth and in my face groove tubes
candyliquor35m
Is anyone else having this problem. Do I have to choose? It means swapping out cd players depending on what mood I'm in. Is it worth it.
Post edited by candyliquor35m on
Hi, just pick one and live with it
. Good luck. -
Yep. Just pick one. You can always change tubes to suit different tastes, but changing CDPs is a bit much.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Two schools of thought:
1. Use the set that leaves the music closest to it's original form
2. Go with the pair that is most pleasing to your own ears.Review Site_ (((AudioPursuit)))
Former Staff Member TONEAudio
2 Ch. System
Cable/Wires: Cardas, AudioArt, Shunyata Venom 3 -
Well put markmarc.engtaz
