I'm torn between old stock tube warmth and in my face groove tubes
candyliquor35m
candyliquor35m Posts: 2,267
edited May 2007 in 2 Channel Audio
Is anyone else having this problem. Do I have to choose? It means swapping out cd players depending on what mood I'm in. Is it worth it.
Post edited by candyliquor35m on
  • crossroads
    crossroads Posts: 32
    edited May 2007
    Hi, just pick one and live with it :) . Good luck.
  • Early B.
    Early B. Posts: 7,900
    edited May 2007
    Yep. Just pick one. You can always change tubes to suit different tastes, but changing CDPs is a bit much.
    "God grooves with tubes."
  • markmarc
    markmarc Posts: 2,309
    edited May 2007
    Two schools of thought:
    1. Use the set that leaves the music closest to it's original form
    2. Go with the pair that is most pleasing to your own ears.
    Former Staff Member TONEAudio
    2 Ch. System
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    Well put markmarc.
    engtaz
