Even lower Bass than Sub Bass......
treitz3
treitz3 Posts: 19,988
edited November 2009 in 2 Channel Audio
Has/Does anybody use one of these?
http://www.rotarywoofer.com/
At 12K professionally installed, would it work? Thoughts?
Post edited by treitz3 on
  • toddco
    toddco Posts: 147
    edited May 2007
    I use one in the summer time if it gets Hot in my room:)
    RTi12's:D
    CSi5
    FXi5
    CSi3
    PB12+2 :cool:
    Sony STR-DA2ES
    Outlaw M200 x3
    SMS 1
    Signal Ultra
    Sig.2 Inters.
    PS 3
    Xbox360 Elite
    PHILLIPS 42" PLAS. 1080i
    Monster 5100 SS
  • cmy330go
    cmy330go Posts: 2,341
    edited May 2007
    From what I have read they are quite a performer. I think if you do a search you'll find an old thread about this sub.
    Here it is. **LINK**
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • Sherardp
    Sherardp Posts: 8,038
    edited May 2007
    just seem them in Sound and Vision and supposedly they can go really low.
  • lightman1
    lightman1 Posts: 10,796
    edited May 2007
    Jumpin' Jesus on a Pogo Stick!! I'd have to re-plaster my walls after listening to the THX sweep at the start of the movie!!!
    edited May 2007
    So none of you have heard this component or had a buddy that has or had one installed?
    I'm not in any hurry, but in a couple of years my wife and I want to build a dedicated stereo room and I am interested in this. 12K is a little expensive to me to dive into without at least hearing or having a recommendation or two as to yea or nea.
    Anybody?
  • jm1
    jm1 Posts: 618
    edited May 2007
    What kind of overall response are you looking for? In my treated room, I have controlled bass with a -3dB at about 11-12Hz. Do you feel you need to go lower than this?
    Personally, I would suggest one (or more depending on your room size) SVS PC-Ultras (I have two) and invest the remainder of the $12K in designing builtin room acoustics (include the ceiling) and better speakers than you were planning.
    All truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident.
    Arthur Schopenhauer
    edited May 2007
    This may sound strange, but I'm not looking for response, I'm looking for more accurate bass at the extreme low end without having that dreaded "boom" at the bottom. Numbers, waveforms, frequencies, ballistics, amperage, wattage, dampening factors and a slew of other factors are obviously important when choosing gear for one's rig........synergy and the end result as to what ultimately hits your ears, whether it be sound or "feel" in this case is to me, the most important thing.
    Another thread, http://www.polkaudio.com/forums/showthread.php?t=53127 has what some folks consider bass. Bass and subsonic bass that does exist in real sound, to me [and not midbass] must be IMO able to be reproduced better with new technology -vs- a woofer. The end result should, in theory, sound more realistic in it's reproduction. That is why I am interested in this gear.
    It may be that it does not kick in very often, and I'm OK with that. I have an available 2,501 watts on my stereo.....do I use it all the time? No. When it is needed, I would like it to be there, though. Same with this sub (in conjunction with the rest of my rig).
    It would be nice to hear it, or at the very least a review from someone who will not offer a biased opinion, you know?
  • Yashu
    Yashu Posts: 772
    edited May 2007
    I had a herbie hancock record that would make my woofers move quite a bit at about 2-5hz, I always wondered what that would "sound" like if I actually got real response at that freq.
    If you buy this vane-sub I will lone you the record and you can let me know ;)
  • amulford
    amulford Posts: 5,020
    edited May 2007
    12k? Try doubling that:
    Rotary Woofer Pricing:
    TRW-17 transducer $12,900.00
    Motor Controller $350.00
    Amplifier and crossover $700.00
    Design and installation, typical $8,000-$12,000*
    Total $21,950-$25,950
    *Note, design and installation fees include:
    1. consulting engineering for the installation,
    2. design and construction of the manifold at Eminent Technology
    3. installation and setup of the TRW-17 by Eminent Technology
    4. measurement and performance testing of the finished installation
    5. travel for Eminent Technology employees
    6. contractor fees for construction necessary for the installation
    edited June 2007
    I read this thread when you posted it. I have been at a loss of words until now. I have to be at a better place in my journey of life to install this, however this does give me plenty of motivation!
    I'd still like to hear it and it's effects. TXS!
    El Bumparoonie! Blast from the past, eh? I'd still like to get my ears on one of these things. Anybody here got one or know someone that's got one I could listen too? Any demo rooms at a dealership.
    Throw me a bone here.
  • w_coyote
    w_coyote Posts: 66
    I have read a couple of articles(don't remember where) about it but have never read where you could demo it. One article said it would go down to 1hz. Don't know if its true or not. The other article said that they installed two of these in a big church in NYC and had to remove one because there was so structural flexing. Again don't know if it's true but thats what i've read.
  • TNRabbit
    TNRabbit Posts: 2,168
    Tom, I have 4 of them installed in my home, or what is left of it. They are OFF THE HOOK~
    :D:D:D:D:D
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
