Yes, Fragile on DVD A - pauses between tracks?
Dforzano
I just picked up the multi-channel DVD-Audio release of Yes, Fragile. Sonically I'm pretty impressed, but much to my dismay there are audible pauses in playback between tracks where there shouldn't be - the most noticeable being between "Long Distance Runaround" and "The Fish".
As this is my first DVD-Aduio purchase I'm curious if anyone else has experienced this problem with this, or any other DVD-A title?
I'm not sure which will upset me more, that it's my player that is introducing the error, or a limitation of the format or title.
I'm playing back on a Toshiba SD5700 DVD/DVDA deck in 6 channel analog.
Thanks,
:Dan
Thanks,
:Dan
Post edited by Dforzano on
I have not experienced this pause you talk about.. i've got about 10 DVD-a discs.. but i do notice that sometimes i'll hear a song or two get "clipped" by a half second or so.. at the beginning of it usually. I think that is something associated with the DVD format. and not all DVD-a discs are like that.PolkFest 2012, who's going>?
