5 channel tube AMP
JimBRICK
JimBRICK Posts: 1,543
edited May 2007 in Electronics
I saw a 5 channel home theater tube amp from butler
http://www.butleraudio.com/tdb5150.php
is there any other companies that make something like this that are a little more affordable????
2 CHANNEL
Speaker - Klipsch Heresy II
Under construction
Post edited by JimBRICK on
  • dane_peterson
    dane_peterson Posts: 1,903
    edited May 2007
    That's pretty affordable if you ask me. But I'm curious to see the results as well. *subscribed*
  • Early B.
    Early B. Posts: 7,900
    edited May 2007
    If I had the money, this amp would be on my very short list to try out.
    "God grooves with tubes."
  • venomclan
    venomclan Posts: 2,467
    edited May 2007
    I believe these amps are hybris ss and tube amps. I have heard good things about them but never demo'd them. I think Antique Sound Labs make small affordable tube monoblocks. Check out audioadvisor.com, they used to carry them.
    v
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited May 2007
    They are Hybrid, it's still sand power at the end of the day.
    tonyb Posts: 33,067
    edited May 2007
    I have the TDB 2250 and can't say enough good things about it.Balls to drive anything with alittle sweet tube sound on top.PERFECT for me.Butler is also comming out with a tubed AVR soon.6 moons has a nice write up on the amp.
