Tube compatability question
riglehart
Can you indescriminately swap between all of these without dire conscequences?
ECC81
ECC82
ECC83
12ax7
12au7
12at7
I've used 12ax7 in place of ECC82 and 12au7. My Jolida has two each 12at7 and 12ax7, and I've put four 12ax7 in it at the same time.
I have not ran into problems, but maybe beginners luck?
ECC81
ECC82
ECC83
12ax7
12au7
12at7
Jolida Tube
Polk 11T, 7, 5, 5jr, 4
Standard equip not worth bragging about.
Post edited by riglehart on
You can almost always go down in gain, going up isn't recommened, unless you are sure the specific circuit can handle it.
Gain factor 101 ->
http://thetubestore.com/gainfactor.html
Cheers,
RussCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
