Need help with speaker Grille
DMS44
DMS44 Posts: 6
edited May 2007 in DIY, Mods & Tweaks
I am looking to recess my bookshelf speakers into the wall and have them look like in wall speakers. My plan is to use the in wall speaker grilles in order to give it the look of an inwall speaker. My question is does anyone know where I can purchase the polk in wall speaker grilles, I have looked around but not seen anything. Thanks for any help on this.
Post edited by DMS44 on
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited May 2007
    Not the best idea to stick a bookshelf speaker into a hole in the wall. The sound will most likely be boomy and your imaging will suffer. My 2 cents.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • zingo
    zingo Posts: 11,258
    edited May 2007
    I agree with scott. Free standing speakers are not usually designed to be enclosed. Is it possible to get your hands on some in-wall speakers, or do you really like your bookshelves. (I can totally understand that) You could try it out and see if you like it though. As far as the grills go, try contacting Polk directly and they might be able ship you some grills that fit the dimentions you are looking for.
