SL1000 Replacement Tweeters
WolfKiyoshi
i was just wondering what the model number of the replacement was how much they cost and if its a drop in or if any modifications are needed? they are technically still my dads speakers
he'd cry if i took tools to them *and i'd cry cutting them up* would anyone have a pic of one?
Post edited by WolfKiyoshi on
replacement HF1000 / SL1000 / SL2000 = RD0194-1
replacement SL2500 / SL3000 = RD0198-1
Mention that you are a Club Polk member when you call customer service.
Bookmark http://www.polkaudio.com/forums/showthread.php?t=25377
The HF1000 / SL1000 replacement requires some modification. If you have a dremel or drill with a grinding attachment it will make this an easy job. You should replace these in pairs. Sell the used ones here or on ebay.
