Splicing Speaker Wire
I ran 12ga. Speaker wire for a 7.1 dedicated HT. I have it in a 3 gang blue electrical box. Before the room was drywalled I shoved it into a pipe and taped it off so they wouldn't cut into it when they routed around the electrical boxes. Sure enough they somehow managed to cut into my wires. I left a little bit of a service loop up top, and the closet the wire is run into I installed a drop ceiling. Originally wanted to run the wires directly into the amp. Now I'm afraid they will be too short even after taking out the service loop. Should I:
A. Splice the wires to extend them a couple feet
B. Put them on Banana or Binding Post Jacks
C. Run new wires
D. Other
Is there any signal loss when using jacks and splicing?
Post edited by Snagglepuss1318 on
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    C. run new wires. They will be in there for a while. Do it now, before you have to do it later.
    engtaz
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    Never cheat yourself with regret.
    engtaz
    heiney9 Posts: 25,432
    edited April 2007
    Run new wires unless it's a big hassel. If the new wires aren't an option the next best solution is to twist the wires and secure/seal them with shrink tubing. It's better than wire nuts or any type of splicing connector.
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited April 2007
    What about using a good silver solder, and the shrink wrap tubing? (I have a couple shorter than desired cables myself...):o
    edited April 2007
    That woould work even better. Shrink tubing is nice because it eliminates the need for solder, but you can use the solder and shrink tubing for the ultimate long term connection.
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited April 2007
    +1 on that. Just did a repair on a battery powered mixer for one of the local bingo hall and did just what you said. Because it is just an electrical connection and not a signal path I used rosin core solder. Any thing with an audio signal going threw it I like to use silver. Best choice in my opinion would be to run new wires, but the solder is defiantly a close second.
  • Snagglepuss1318
    Snagglepuss1318 Posts: 61
    edited April 2007
    Any known signal loss from splicing or jacks?
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    splicing with solder and shrink tubing, no. any crimp type can allow bad contact orver time.
    engtaz
  • crd2002
    crd2002 Posts: 174
    edited April 2007
    they make a double sided connecter you put the wire in on each side and its insulated on the outside
    Home Theater sony 52 inch lcd,Cinenova grande 7 channel, polk RTI8,CSI5,FXI5,onkyo 805
    2 Channel rig Sunfire grand cinema 5ch,sunfire TGA III,Rotel 1072,polk RTI12,Monster hts 5100
  • Lowell_M
    Lowell_M Posts: 1,660
    edited April 2007
    +1 more on the solder and shrink tubing. I actually had to do the same thing for a different reason in my basement.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • dudeinaroom
    edited April 2007
    do not use butt connectors or scotch locks!!!!!
  • vonnie123
    vonnie123 Posts: 326
    edited April 2007
    I needed to extend some high quality speaker cables in the past....the solder and shrink tubing method works pretty well.....I couldn't perceive any signal loss or change in the music delivery.
