rectifier
james838
neeed help!
rectifier for dared sl2000a 5z4p cant find one
Anyone know what else would i be able to use I am new at this.
Post edited by james838 on
private message RuSsMaN on here.. he knows tons about tubes.
good luck and welcome to club Polk.PolkFest 2012, who's going>?
your best bet if you are having trouble finding that exact tube.. call up Dared or the seller where you bought the pre amp.PolkFest 2012, who's going>?
I have called dared no response as yet
I have read that sometimes there are two or three rectifier codes that may fit so I am hoping someone with same model can give some advice -
Talk to this guy and see if he can help.
JSPHT8338@aol.com
I buy most of my tubes from him and he has a great deal of knowledge on tubes.Testing
Testing
Testing -
i gotta ask, what happen to the rectifer tube that you need a new one?PolkFest 2012, who's going>?
I dont know. It turns purple when it is switched on and keeps flashing and making popping noises which it never done before
