rectifier
james838
james838 Posts: 6
edited April 2007 in Electronics
neeed help!
rectifier for dared sl2000a 5z4p cant find one
Anyone know what else would i be able to use I am new at this.
Post edited by james838 on
  • danger boy
    danger boy Posts: 15,722
    edited April 2007
    private message RuSsMaN on here.. he knows tons about tubes.
    good luck and welcome to club Polk.
    PolkFest 2012, who's going>?
  • danger boy
    edited April 2007
    your best bet if you are having trouble finding that exact tube.. call up Dared or the seller where you bought the pre amp.
  • james838
    james838 Posts: 6
    edited April 2007
    I have called dared no response as yet
    I have read that sometimes there are two or three rectifier codes that may fit so I am hoping someone with same model can give some advice
  • Systems
    Systems Posts: 14,872
    edited April 2007
    Talk to this guy and see if he can help.
    JSPHT8338@aol.com
    I buy most of my tubes from him and he has a great deal of knowledge on tubes.
    Testing
    Testing
    Testing
  • danger boy
    edited April 2007
    james838 wrote: »
    i gotta ask, what happen to the rectifer tube that you need a new one?
  • james838
    james838 Posts: 6
    edited April 2007
    I dont know. It turns purple when it is switched on and keeps flashing and making popping noises which it never done before
