Cambridge Audio
NJPOLKER
NJPOLKER Posts: 3,474
edited April 2007 in Vintage Speakers
I picked up a Cambridge Audio A500 integrated amp for $170. I thought it was a ok deal so bought it thinking I will run my spare Monitor 10's with it.
Do you think it is a good buy and could I also use it for my SDA2's ?
Thanks Drew
Post edited by NJPOLKER on
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2007
    Great buy and yes.
  • NJPOLKER
    edited April 2007
    I guess I should have come right and asked if you know if the Cambridge Audio A500 is a common ground integrated amp.?
  • dorokusai
    edited April 2007
    Common ground. The disclaimer should always be, check with a VOM(Voltmeter).
