Sub help?
Nashvilletitans
Nashvilletitans Posts: 80
edited November 2001 in Technical/Setup
I have a new psw250( iknow i know,was all I could afford) and a Denon AVR1802. The manual shows it to have a LFE input, but mine does not. I really don't want to do the amp-sub-speaker routine I don't think. I have SDA2b fronts. I might try my L/R RCA outs from my amp to the L/R RCA ins on the sub. Any suggestions? Thanks John
Post edited by Nashvilletitans on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited October 2001
    Hello John,
    Thanks for participating in the Forum. The owner's manual should indicate the PSW250 as being the exception on having the LFE input. The correct connection method will be an RCA cable coming from the receiver's sub-out to either the right or left line level input on the PSW250. Many people choose to use a "Y" cable to provide an input to both right and left channels. While this doesn't change the character of the sound, it does increase the output volume at each sub-woofer volume position.
    The other important consideration is to rotate the low pass filter adjustment, on the PSW250, to the maximum setting. This avoids any additional filtering of the incoming signal.
    Regards, Ken Swauger
  • Nashvilletitans
    Thanks for the help Ken.
  • [Deleted User]
    You're welcome, glad to be of help.
    Have fun, Ken
