Small or large?
I have the Polk Rti10s and a Velodyne DLS-4000R Subwoofer. Should i set the speakers to small or large? and what should I set the crossover to?
Post edited by 1lakerfan on
IMO, I would set the RTi10's to small and x-overs to either 60 or 80Hz.
Set the 10's to LARGE. There's no point having a large speaker and setting them on SMALL.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Ed Zachry.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
I set mine to large, If they aren't distorting why not.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I'd try it different ways: large with the sub rolled off at 50 -100Hz; and small, crossed over to the sub in the same range. I'd listen with some really good quality bass CD's with the volume cranked up pretty good (but clean). If you have an spl meter and/or test CD with tones going down into the low bass, that would be helpful too. Whatever sounds the best is the best!THE MAN-CAVE 5.1 CHANNEL A/V RIG
Sony KDS-60A3000
a/d/s/ HT-400LCR (3)
a/d/s/ HT-300 (2)
Velodyne DLS-4000R (2)
Pioneer Elite VSX-55TXi
Pioneer Elite DV-47Ai
Sony BDP-S300
Sony SLV-779HF
DirecTV HD sat. receiver
MAN-CAVE 2-CHANNEL RIG (shares sources with a/v system)
Adcom GFA-5500
Bose 901 Series VI
NAD C-165BEE
Slim Devices Squeezebox Classic
TEAC CD-RW890
Technics SL-BD20D w/ Audio-Technica P34
Akai HX-A3X -
Everything I've read says to set to small regardless of the speakers. You have to try it both ways & listen to what sounds best to you. From what I can gather if you set to large you are missing out on some of the LFE info. If that's true I couldn't say.
pearsall001 wrote: »From what I can gather if you set to large you are missing out on some of the LFE info. If that's true I couldn't say.
Just the opposite is true.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
It depends on receiver/amp power. Headroom is used up pretty quickly at higher volumes with a receiver, and compression is bound to happen or worse, thermal shutdown.
The 10s are large enough to run large, if your amp is big enough.
I always try it both ways and use the setting that delivers the cleanest, most defined sound, free of midbass bloatiness and it has almost always been small settings in most of my installs. So get your listen on...........HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
"I always try it both ways and use the setting that delivers the cleanest, most defined sound, free of midbass bloatiness and it has almost always been small settings in most of my installs. So get your listen on..........."
I agreeengtaz
MediumPolitical Correctness'.........defined
President of Club Polk -
You know, I never did try my 8's as large since I bought my mono's..Hmmmm
I did lower the xover to 60hz. -
I agree with F1. And make sure the sub is set sometimes.
I would have them set to large, but if they were here the would be rears with the sda's pulling main duty. I also do not really have a choice to set my mains as small, I sold my sub, and my sda's put out enough bass for my apartment,yeah I know I'm not getting the lowest bass but that's apartment life. the sda's and the adcom still do enough to make the neighbors mad(not that I try).
I have a Denon AVR-2807 reciever. When I put the reciver to small it seems that I get the cleanest sound on 40 Hz. When you put the speaker to large are you supposed to change the crossover on the subwoofer? because when I set the speaker large the setting of changing the crossver to the fronts goes away. I have the recivever connected to the subwoofer through the LFE with what I think its called a Y-adapter.
