is this the answer to my power needs?
JimBRICK
JimBRICK Posts: 1,543
edited April 2007 in Electronics
Model JD 1704RC
http://www.jolida.com/catalogue/models/jd1704rc.shtml
and add this with it
http://www.jolida.com/catalogue/models/jd1501rc.shtml
5.1 heaven I think
this is for my lsi15's, lsic and my subwoofer which I havent purchased yet
2 CHANNEL
Speaker - Klipsch Heresy II
Under construction
Post edited by JimBRICK on
  • hearingimpared
    hearingimpared Posts: 21,136
    edited April 2007
    If nothing else it is pretty!
  • zingo
    zingo Posts: 11,258
    edited April 2007
    That is only five channels, so as long as you have a self-powered sub, that does answer your power needs. And I do agree, they are so pretty... Brushed aluminum has always been a good look.
  • AndyGwis
    AndyGwis Posts: 3,655
    edited April 2007
    So, you can hook up 5.1 analog outs from a DVP to that combo?!? Then, hook up all your 2 channel stuff directly to the integrated stereo amp?
    That actually sounds like a pretty cool concept, but probably pricey as hell :)
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • JimBRICK
    edited April 2007
    you can get both units for around 1500 bucks. What I want to know is since there is no dolby and dts processing in these, what do I use to process them since there is no digital input.
    2 CHANNEL
    Under construction
  • WilliamM2
    WilliamM2 Posts: 4,804
    edited April 2007
    The input sensitivity, and input impedence of the two units do not match, it may be difficult to get a good level match on all 5 speakers.
    I find it curious that bandwidth of both units is 22hz to 19Khz at +/-3db? Most amps are flat from at least 20hz to 20Khz, or at most +/- .5db.
    And distortion is rated at less than full rated power.
  • JimBRICK
    edited April 2007
    ok I'm really new to seperates but I have a question. they say on the website that these work as a team. but I cant see how they connect together at all to work as a team
    2 CHANNEL
    Under construction
