Csi5 height
Can anyone tell me if the height is affected if you turn the Csi5 upside down and use the angled top to place the speaker under your TV? I want to purchase the Csi5 to compliment my RTi8's but want to make sure I have the room! If it does and someone can provide me measurements that would be great. Thx.
Please check this pic out if I'm not making sense: http://www.polkaudio.com/images/global/center/CSiUpsideDown.jpg
Post edited by sdavisgsx on
CSi5 is 7 3/4 high. In the pic you provided it would be 8 3/4.
You can always use the pedestal to aim the speaker down to ear level if you place it above the screen or use a wedge to put in front to have it firing up to ear level.Shoot the jumper.....................BALLIN.............!!!!!
