What does Polk filtered mean?
Sumflow
The Polk subwoofer outlet port label suggests that you to put the Amp outlet wires into it.
What exactly is the purpose of Polk labels on Subwoofers anyway?
To be consistent with Polk labeling we would need to put a filtered line into a Polk filtered port. Or an unfiltered line into a Polk unfiltered port.
Does Polk really want us to put the Amps filtered cable into the Subwoofers filtered labeled port?
Does it mean the port is filtered so that you have to put an unfiltered signal into it?
Or does it mean it is unfiltered so you have to put a filtered source into it?
"At the first bend, I had the clear sensation that Tazio had taken it badly and that we would end up in the ditch; I felt myself stiffen as I waited for the crunch. Instead, we found ourselves on the next straight with the car in a perfect position. I looked at him, his rugged face was calm, just as it always was, and certainly not the face of someone who had just escaped a hair-raising spin. I had the same sensation at the second bend. By the fourth or fifth bend I began to understand; in the meantime, I had noticed that through the entire bend Tazio did not lift his foot from the accelerator, and that, in fact, it was flat on the floor. As bend followed bend, I discovered his secret. Nuvolari entered the bend somewhat earlier than my driver's instinct would have told me to. But he went into the bend in an unusual way: with one movement he aimed the nose of the car at the inside edge, just where the curve itself started. His foot was flat down, and he had obviously changed down to the right gear before going through this fearsome rigmarole. In this way he put the car into a four-wheel drift, making the most of the thrust of the centrifugal force and keeping it on the road with the traction of the driving wheels. Throughout the bend the car shaved the inside edge, and when the bend turned into the straight the car was in the normal position for accelerating down it, with no need for any corrections."
Enzo Ferrari
Enzo Ferrari
Post edited by Sumflow on
Once again WOW!!!!
Filtered simple means that the crossover in the subwoofer is active.
Unfiltered means that the subwoofer's internal crossover is NOT active.
Just plug in your RCA plug from your LFE (subwoofer) preout on the reciever to the unfiltered input on the sub. Because that signal from your rerciever is already at a certain crossover point.
Now take a deep breath and give it a shot. Good Luck man:) -
Okay, I'm back. It was weekend, what could I do?
The filtered/non-filtered thing is a hot-button, confusing issue. But really it is as simple as scottvamp laid out. You just have to know what goes where and why. Here's some (slightly abridged) text from a Polk manual that may help:
- THE CASE AGAINST SUB-OUT/LFE JACKS
In some cases, the worst place to connect your subwoofer is the SUB-OUT/LFE JACK. Why? Some receivers and processors do not send a signal to the SUB-OUT JACK when they are in the STEREO mode. That means when you listen to music in stereo, you lose the benefit of the subwoofer! Additionally, in the vast majority of receivers and processors, the SUB-OUT/LFE JACK is LOW-PASS FILTERED. That means that there is a filter (sometimes mistakenly referred to as a crossover) that blocks sounds ABOVE a given frequency from getting out of the receiver's SUB-OUT/LFE JACK. Why is that bad? Because your powered subwoofer ALSO has a built-in LOW-PASS FILTER; and when the two filters combine, their interaction can cause irregularities in the frequency response and reduce the fidelity of your system. Not to mention that the variable LOW-PASS FILTER in your powered subwoofer is one of the most useful tools for adjusting your subwoofer to "blend" better with the rest of your system. By using a pre-filtered signal, you are defeating this excellent and useful feature. Unless you have high-end components (some of which allow you to manipulate their low-pass filters), or are certain that your component has an UNFILTERED LFE, it's a good idea to ignore the SUB-OUT/LFE JACK of your electronics. You will get better performance, and not miss any bass, when you just trust us and let go.
How do you tell whether or not a jack is filtered? You use a simple test (again from a manual):
HOW TO TELL IF YOUR SUB-OUT/LFE JACK IS FILTERED OR UNFILTERED
Use the "bass management" or "speaker setup" function of your multi-channel receiver or digital processor to select the subwoofer as ON or YES. Connect the SUB-OUT or LFE OUT jack of your electronics to the LFE INPUT of your subwoofer. Disconnect the other speakers in the system so that all you can hear is the subwoofer. Play music or a movie with vocal content. If you can hear and understand the words, your SUB-OUT JACK is NOT FILTERED. If all you can hear is bass, and the vocals are barely or not at all audible, your SUB-OUT JACK IS FILTERED.
I hope this helps. It would also help if we knew what kind of equipment you're using and which Polk speakers you're using.
Monday morning!
Micah -
Think his issue is that his sub doesn't have an LFE input. Thus he's forced to use the line level inputs.Damn....8 lines...I've gotta put my sig on a diet now.... -
Tony - maybe but most likely not.
Strange guy so far - only post in bold blue and red. Must take forever.
And ask tons of questions in tangents. Twilight Zone man!!!:eek: -
*BSOD*
Also because POLK is very pro on idiot proofing setup of spreakers (which is a good thing). I quess I should stop promoting LFE installs all the time.
Sorry Micah my bad. Thanks for bringing the new info to our attention.
AlsoOkay, I'm back. It was weekend, what could I do? -
I mean come on you work for POLK - wwwwwwell then again I have seen your HT setup. :eek:
YES!, and Scott LEAPS off the top turnbuckle!!! POW!
Cheers,
RoosterCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Micah, man, don't forget to loosen the tourniquet every 10 minutes.
Originally posted by TonyPTX What I really have trouble with is taking Polk advice on speakers when there advice on setup makes so little sense.
you're doing your own analysis of what you "think" is right (i.e. using your knowledge of speaker systems and applying it here.)"how to assemble build a computer" or "rebuild a 4 bbl Holley carb," you would be a little less resistant to questioning the validity or accuracy of the instructions.
How can you set something up by the book, when the books language is inconsistent with the usual way English is normally used?Originally posted by scottvamp Just plug in your RCA plug from your LFE (subwoofer) preout on the receiver to the unfiltered input on the sub.Originally posted by Micah You just have to know what goes where and why. Here's some (slightly abridged) text from a Polk manual that may help.
Why cant you please send the hard questions up to someone in Mr. Polks office that does not write his manuals or lick his boot and explain how Polks manual is supposed to make sense?You will get better performance, and not miss any bass, when you just trust us and let go.I hope this helps. It would also help if we knew what kind of equipment you're using and which Polk speakers you're using.
One more observation I would like to make. If I am at home with wireless broadband, I would scour this site to try to find the answers hidden wherever they are. But I am on the road. This current 56k takes so long to load a page that searching is not an option.
I have taken some time, asked a few questions. My Polk sound is OK. But I am not impressed with Polk, the owners manual or the help I am not getting from this discussion group."At the first bend, I had the clear sensation that Tazio had taken it badly and that we would end up in the ditch; I felt myself stiffen as I waited for the crunch. Instead, we found ourselves on the next straight with the car in a perfect position. I looked at him, his rugged face was calm, just as it always was, and certainly not the face of someone who had just escaped a hair-raising spin. I had the same sensation at the second bend. By the fourth or fifth bend I began to understand; in the meantime, I had noticed that through the entire bend Tazio did not lift his foot from the accelerator, and that, in fact, it was flat on the floor. As bend followed bend, I discovered his secret. Nuvolari entered the bend somewhat earlier than my driver's instinct would have told me to. But he went into the bend in an unusual way: with one movement he aimed the nose of the car at the inside edge, just where the curve itself started. His foot was flat down, and he had obviously changed down to the right gear before going through this fearsome rigmarole. In this way he put the car into a four-wheel drift, making the most of the thrust of the centrifugal force and keeping it on the road with the traction of the driving wheels. Throughout the bend the car shaved the inside edge, and when the bend turned into the straight the car was in the normal position for accelerating down it, with no need for any corrections."
Enzo Ferrari -
Friendly suggestion....check attitude at door and please stop posting in colors, it's like using caps, just not cool.
Try contacting Ken in customer service, www.KSwauger@polkaudio.com. He's very good.Political Correctness'.........defined
President of Club Polk -
Someone please scan these pages and post them for us. I think someone isn't quite understanding something in the manual.
Seriously though Phuz, the diagrams/figures in the PSW303/404 manual are wrong which is the point that I think Sumflow is trying to make (or get someone to own up to). Which may also explain why the manual for the 303/404 is not available online.
If you read the instructions for Polks recommended setup (i.e. the WORDS), they are correct. However, if you're one of those folks who skip the "written words" and go straight to the meat of the manual, the pictures/figures, the figure that corresponds with the "word instructions" is not accurate. IN the picture they show the speaker wiring setup as speaker line level out of the receiver to the speaker line level out on the subwoofer (NOT the speaker line level in on the subwoofer as common sense would have you hook it up). They then have wires from the "Speaker line Level In on the Subwoofer" running to the Front L/R sats. An honest mistake that a drafter made when they sketched the illustration for the manual.
I guess that Sumflow feels that if they incorrectly labeled the figures, then "what else is incorrectly labeled" is his logic.
Am I right here Sumflow? Honestly, I'd trust the labeling on back of the sub before I'd trust the manual.
PS. I can't scan the 303/404 manual for you since I don't have a scanner. Maybe I can take a dig pic of it tonight and post it.Damn....8 lines...I've gotta put my sig on a diet now.... -
If you took all the girls I knew
When I was single
And brought them all together
For one night
I know they'd never match
My sweet imagination
Everything looks worse
In black and white
Kodachrome
They give us those nice bright colors
They give us the greens of summers
Makes you think all the world's
A sunny day
I got a Nikon camera
I love to a photograph
So mama don't take my Kodachrome away"At the first bend, I had the clear sensation that Tazio had taken it badly and that we would end up in the ditch; I felt myself stiffen as I waited for the crunch. Instead, we found ourselves on the next straight with the car in a perfect position. I looked at him, his rugged face was calm, just as it always was, and certainly not the face of someone who had just escaped a hair-raising spin. I had the same sensation at the second bend. By the fourth or fifth bend I began to understand; in the meantime, I had noticed that through the entire bend Tazio did not lift his foot from the accelerator, and that, in fact, it was flat on the floor. As bend followed bend, I discovered his secret. Nuvolari entered the bend somewhat earlier than my driver's instinct would have told me to. But he went into the bend in an unusual way: with one movement he aimed the nose of the car at the inside edge, just where the curve itself started. His foot was flat down, and he had obviously changed down to the right gear before going through this fearsome rigmarole. In this way he put the car into a four-wheel drift, making the most of the thrust of the centrifugal force and keeping it on the road with the traction of the driving wheels. Throughout the bend the car shaved the inside edge, and when the bend turned into the straight the car was in the normal position for accelerating down it, with no need for any corrections."
Enzo Ferrari -
Nope, you bet wrong! Try again. :rolleyes:Political Correctness'.........defined
Thanks for the explanation TonyPTX.
See photos below:Damn....8 lines...I've gotta put my sig on a diet now.... -
Tony I think you can only post one photo in each post.
You don't have to go through the trouble of posting them if you don't want to. With two people saying the same thing I have to believe it. -
You have honestly HiJack3d this thread.....so much for attempting to make some ground on this.
HOWEVER...the pict is still funny as hellDamn....8 lines...I've gotta put my sig on a diet now.... -
Tony,
I did try to help Sumflow with his questions, but he seems to have a little attitude thing. Anyway, sorry for the hijacking.
The pic is truly in "nice bright colors"....:DPolitical Correctness'.........defined
Originally posted by TonyPTX ..mistake that a drafter made when they sketched the illustration for the manual.
Draftsperson innocent!The drafts person cannot make a mistake as you suggest. The artist works for someone else. They are told what to draw. The artist is not a free agent. They turn in there work. The supervisor accepts it and sends them back to the drawing board.
"Schematics,"After Polk accepts the drawing, it has to go through the same quality control as schematics and other Polk technical drawings used in production. If the supervisor was not trained correctly, this does not fall on the hapless artist. It does however reflect on the reputation of the company.
Actually it is more important that the stuff they feed the public be correct because mistakes made inside are not as obvious.
The Emperors new clothes!Polk is in an interesting position. People spend a good chunk of a weeks take home pay on a set of Home Theater speakers. They have a vested interest in believing in what they bought.
"Acoustical Advantage!"
Pokies have no way to compare these speakers against any others except in sound rooms often manned by Polk commissioned sales persons. People who place Polk products to there acoustical advantage against similar products.
"Out of phase Mono!" I am sure we could go into the average first time buyers home, put in a Mono DVD. Play one side out of phase. After spending all that money, these people would say it was the best sound they had ever heard, and probably be right. How would they know?
"Movie theater Sound!" I have been in Movie theaters coast to coast. I lived in Hollywood, been to openings in Westwood. There is no consistency in Movie theater sound. A lot depends on where you sit in the theater and how many people are in there soaking up the sound. I think the theater owners that are not blind are for sure deaf.
"Press always positive!" Magazine testers and critics are always given top stuff. If something ever did turn out faulty, they would give the manufacturer the benefit of the doubt and be given another test product. Besides speaker makers have been know to pay for advertising. Big business is not in the habit of antagonizing future sponsors.
"Home Theater CD!" Maybe Home Theater is just for Movie sounds. When I visit sound rooms in Circuit City, the Good Guys, and countless stores across America. I wonder why sales people are not embarrassed when they play Rock & Roll CDs on Home Theater Systems. They dont sound anything like a recording studio blasting through studio monitors.
Thanks Tony, Again you are very perceptive and get right to the heart of the matter. If Polks drawings are erroneous on how to use them, then the drawings could just as easily be amiss on how to make them.
When a person reads the Polk Manuel with half a brain they will see no inconsistently and still have a 50% chance of being correct. Nevertheless, anyone that uses the whole brain will be stuck with the inconsistently. Of course this is assuming that the manufacture is marketing to people who know how to read. If they do not this will never come up. Do you think other Pokies will understand this or do I have to explain to them about how the halves of the human brain work?Am I right here Sumflow? Honestly, I'd trust the labeling on back of the sub before I'd trust the manual.
Tony people who spend a weeks take home pay deserve to do more than just Guess!!
What about all the other people who buy Polk products.
The bottom line is "Polk sold us defective merchandise!" When Polk lets shoddy stuff get through on the outside, it implies shoddy stuff on the inside.
Enzo Ferrari -
I give up....
You can lead a horse to water....Damn....8 lines...I've gotta put my sig on a diet now.... -
Honestly if you know how to hook it up don't worry about it, some of the biggest companies out there will have type O's in the manual and also have amended manuals when you receive them in the form of a pull out inserted into the manual. Geez get over it!! This deosnt mean Polk is **** up speakers they made a graphical mistake in the book,MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
here is a amended pull out for the 404 i just bought, notice the wire level input diagram, corrected...MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Originally posted by faster100 "amended pull out,"
Why?
The Polk web site says"Resist all temptation to use the subwoofer output jack-please."
Why?some of the biggest companies out there..
The Polk website says maybe those big electronics companies are just not paying any attention to the speaker business.
In the case of the PWS303 there is no amended pull out. The products were shipped by Mr Polk and his agents as defective. There is no explaniation on the web site. A person with less persistence than me could take over a week getting an answer off of this users forum.
You still have not shown that there is anyway consumers can tell if the hardware part of the product contains omissions and defects.
Do you still have your Enron shares?"At the first bend, I had the clear sensation that Tazio had taken it badly and that we would end up in the ditch; I felt myself stiffen as I waited for the crunch. Instead, we found ourselves on the next straight with the car in a perfect position. I looked at him, his rugged face was calm, just as it always was, and certainly not the face of someone who had just escaped a hair-raising spin. I had the same sensation at the second bend. By the fourth or fifth bend I began to understand; in the meantime, I had noticed that through the entire bend Tazio did not lift his foot from the accelerator, and that, in fact, it was flat on the floor. As bend followed bend, I discovered his secret. Nuvolari entered the bend somewhat earlier than my driver's instinct would have told me to. But he went into the bend in an unusual way: with one movement he aimed the nose of the car at the inside edge, just where the curve itself started. His foot was flat down, and he had obviously changed down to the right gear before going through this fearsome rigmarole. In this way he put the car into a four-wheel drift, making the most of the thrust of the centrifugal force and keeping it on the road with the traction of the driving wheels. Throughout the bend the car shaved the inside edge, and when the bend turned into the straight the car was in the normal position for accelerating down it, with no need for any corrections."
Enzo Ferrari -
This thread is pure comedy.
Peace Out~:DIf...
Ron loves a film = don't even rent. -
Somebody call the **** WHAAAAAmbulance.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Sumflow, if you see this.....then you have omissions and defects.Political Correctness'.........defined
