Monitor 5b's x-over upgrade w/pics
24567
  • Ricardo
    Ricardo Posts: 10,636
    edited April 2007
    Great job/thread. You'll love the new tweeters.
    Here's the Vampire web for your next purchases:
    http://www.vampirewire.com/
    SOPA
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    What is the differences in the different Monitor 5's?
    engtaz
    engtaz
    heiney9 Posts: 25,444
    edited April 2007
    engtaz wrote: »
    engtaz
    Not much other than the tweeters they used over the years and some minor x-over changes which may or may not follow the tweeter changes.
    Early versions of the 5b's (including most of the monitor series as well) had either the peerlees or sl1000 tweeter. I'm not sure which was first (probably the peerless). The early models were fused instead of using a poly switch for tweeter protection. Early 1st gen monitor's also had a paper coned mid driver (if I remember correctly).
    What I call 2nd generation monitors had the sl2000 tweeter which were also fused (but at some point they delete the fuse and put in a poly switch) but some of the early models had 2.7 ohm 5W resistor in tweeter signal path which was later changed to a 2.0 ohm 5W resistor. That change seemed to coincide with the addition of the poly switch. Perhaps the poly switch added a bit of resistance :confused: .
    What I call 3rd generation was the last production run and Polk refered to those as Monitor xx Series II and those had the sl2500 tweeter which had similar sonic charateristics to the sl3000 used in upper end SDA's and RTA's. The sl2500 & sl3000 were designed to get rid of the +6 db @ 13kHZ peak the sl2000 has. The sl2000 uses a silver coil whereas the sl2500 and sl3000 use a tri-laminate material.
    I don't think the peerless version or the sl2500 version schematic is posted in the schematic area. If you have these versions it's best to call Ken and find out the best way to upgrade those, or pull the x-over and get the values from there.
    There is a schematic for a 5b sl3000 mod that is interesting because they add a 5.8 uF cap in parallel with the resistor for the tweeter as well as a slightly higher value inductor. Not sure what effect this has on the output of the tweet, but I may try it down the road as an experiment.
    If I missed anything please add.
    mhardy6647 Posts: 35,041
    edited April 2007
    If you guys want a drop in replacement that is cheap but sounds very good, try the LS00058's from MCM electronics. They are made by a company in Denmark and look uncanningly like the Peerless tweeters that use to be used. I put a couple in my model 10's. I am real happy with them and they only cost $14.25 each. I compared them with the Peerless and thought they sounded spot on. $28.50 isn't much to gamble with.
    Interesting! Can you tell/do you know what material the domes are made of? They look kind of plastic-y/shiny in the photo at MCM.
    edited April 2007
    foxhounds2 wrote: »
    Are you recommending these as replacements for just the peerless models or all the tweeter types used? If you look at the x-overs for the peerless it's quite different than for the other tweets used.
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    Which series are these?
    engtaz
    engtaz
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
    edited April 2007
    engtaz wrote: »
    engtaz
    What I call 2nd gen. You have the sl2000 tweeter and no fuse (so you have a poly switch). You would follow the 2nd Monitor 5b schematic. You have (1) 12uF and (1) 34uF cap and (1) 2.0 ohm 5W resistor. If you are going to upgrade/rebuild your x-overs you can use a 33uF cap in place of the 34uF w/o any consequences.
    Polk will also send you new poly switches for free and if you are going to replace parts then might as well put new poly's in as they can wear out over time.
    Use mylar or polypropelene caps and I highly rec the Mills resistor. Some feel a larger resistor (more resistance) will really tone down the tweeter. The best rec. is to get the new Silk dome replacements from Polk (RD0194-1) for $102 a/pr. shipped.
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    Which tweeter??
    engtaz
    engtaz
    edited April 2007
    heiney9 wrote: »
    Read it's there :)
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    I was typing as you were posting your reply. same time of postings
    Sorry I got you upset but I type slow and this sight hangs up on me sometimes,
    engtaz
    engtaz
    edited April 2007
    engtaz wrote: »
    engtaz
    LOL, I'm not upset at all, that's why I put the smiley. I miss things in posts or post at the same time all the time :)
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    Hey,
    I really appreciate your help and guidance on the Monitor 5's.
    engtaz
    And Adcom advice
    engtaz
  • foxhounds2
    foxhounds2 Posts: 16
    edited April 2007
    heiney9 wrote: »
    I would like some of you folks with more Polk experience to try these out just to see what you think. I was just recommending them for a trial to see what everyone else thinks. When I bought my model 10's a couple of weeks ago I had one with a SL1000 and the other with a Peerless. The peerless seems to be the original but I am not sure. I haven't pulled the crossovers yet to see what parts values are present. When I recieved these tweeters I placed one in the cabinet with the SL1000 and left the Peeerless in the other one. When I compared them I thought that they sounded very much alike in all aspects.I know that this is a subjective process but I have been building, designing speakers for many years and feel like these tweeters are worth a shot for the money. If anyone else tries them I would like to hear your opinion of them.
    Jon Fox
    Life without music would be very bland, imagine not being able to hear. Protect your ears!!!:(
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    george what part # did you order.
    engtaz
    engtaz
  • foxhounds2
    edited April 2007
    If you compare them side by side with the Peerless, they appear to be the same material. I think the picture is reflecting alot of light. In person they aren't as shiny.
    Jon Fox
    edited April 2007
    I just got the new RD0194-1 silk dome tweeters and just installed them. ;)
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    How do you like the sound of the 5's now.
    engtaz
    engtaz
  • george daniel
    george daniel Posts: 12,096
    edited April 2007
    engtaz wrote: »
    engtaz
    Vampire bp hex from partsconnexion,, I thought that I pm'd the parts # :)
    edited April 2007
    engtaz wrote: »
    engtaz
    I'll wait to comment in depth. It wasn't as dramatic as expected but I only have a total of about 2 hours on the tweets and less than 10 hours on the new x-over parts. The main rig has LSi's and going between the two is hard because they are completely different speakers top to bottom and sound totally different.
    If I had to sum it up right now, I'd say the money was very much worth it. I have just under $200 in these 5's and if I didn't have LSi's in the other room I'd be even more thrilled. Judging them just on their own they have really improved and expect as they "break-in" they will get better.
    I highly recommend the tweets and x-over refreshening :);)
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    Did you change the post and why don't you show off your 5's with some pics with the new tweets.
    engtaz
    engtaz
    edited April 2007
    engtaz wrote: »
    engtaz
    No, I didn't change the binding posts. I have enough $$$ invested in these 5b's considering it's for use with a secondary system. I'm sure it's a worthwhile change, but I've gone as far as I will on these.
    I don't currently own a working camera, but my bro does (he's the one who took the x-over pics) so perhaps over the weekend I can post some shots with the new tweeters.
    P.s. Have the RD0 series always had Polk Audio engraved in the plate around the dome? Seems I remember reading the RD0's were kinda flimsy and had no markings. These are very well built units comparable in weight and build quality to the originals.
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    I am using my 5's as center channel so they are on most of the time, so I listened to them before and after install. The A B comparison after changing from 2000 to RDO194 is that the sound spectrum is smoother (even). Voices are more natural. I can't wait for them to break in because it will only get better.
    engtaz
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    OK..I just bought the same tweeter.
    http://www.mcminone.com/product.asp?catalog_name=MCMProducts&product_id=LS00058
    Since I believe my peerless is failing , I will see how it sounds in my center chanell.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited April 2007
    Don't know about always, but the RDO's I bought for my SDA's two years ago have the Polk logo molded in them. And I also thought they were built just as well as the originals.
  • foxhounds2
    edited April 2007
    jakelm wrote: »
    Great, let us all know what you think of it when you get a good comparison. I think it is incredibly smooth and neutral sounding which is what we should really be trying to achieve.
    Jon Fox
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    Just got it in. It looks idintical to the peerless except for the exposed wires on the plate that the peerless have. It sure is a good looking tweeter, if I must say. Not shinny at all, seems to be made up of the same material. (Cloth dome)
    The specs on the back read
    DT-100
    60W/8ohm
    30Wrms (2.5khz/12dB)
    Looks like it has a natrual roll off at almost the same point as the Peerless.
    Very heavy. It feels alittle heavier than the Peerless. It does seem to be built very well.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    edited April 2007
    jakelm wrote: »
    DT-100
    60W/8ohm
    Of course we want to know how it sounds? :D Do you know yet if it's a drop-in or will some slight mods to the cabinet be nec.?
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    How are you speakers sounding?
    engtaz
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    As soon as I get it home tonight, I will drop it in. I recieved it here at work this morning. But as soon as I get home I will give you my thoughts on Sq. I dont have the 2 to compare right now, but it look like the exact same size. But I will see tonight.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
