Lsi speaker mod's?
Pepi28
Pepi28 Posts: 248
edited April 2007 in DIY, Mods & Tweaks
Has anyone ever done any modification's to the LSi speakers' crossover's or electronics to improve their sound or are they too good to make any improvements? Just a thought since I would like to try doing some mod's myself. Also does anyone know of any good mod's for Sunfire amps that I can try. Thanks for any input.
58" Samsung Plasma (on wall)(calibrated)
LSi15's front (modded xo's)
LSic center
LSiFX's sides
LSi7's rears
Sunfire Sig. 600 amp for 15's
Sunfire Sig. Cinema for C,S&R
Sony ES 3000 pre/pro
SVS 2039 PC Plus sub 12.3 (16hz tune)
PS3
Wii
Signal and Audioquest ic's
12 awg monster speaker-cable (bi-wired)
Belkin PF60 power conditioner
Monster power conditioner for sub
Post edited by Pepi28 on
    heiney9 Posts: 25,430
    edited April 2007
    Pepi28 wrote: »
    The LSi's are very good right out of the box. I'm sure some improvements could be made, but the law of diminishing returns would certainly work against you very quickly. If you wanted to spend like $500-1000 on special hand made esoteric caps, resistors and inductors you could find them, but really kind of pointless.
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2007
    I've modified some LSi7 and it was a fun project but I probably wouldn't do it again. I was going to modify my LSi15's but its a very difficult project from my perspective. If you remove the crossover and side firing woofer, you should be able to clearly identify why. You'll have to disconnect the XO harness from all the upper drivers as well so you can remove the entire assembly.
    The main problem is space in the cabinet, as the space on the board for all but minor upgrades is at a premium PLUS you will have to rewire your binders, realize the port is in the way....blah blah.
  • Pepi28
    Pepi28 Posts: 248
    edited April 2007
    I guess I wont be touching my 15's then.
    LSic center
    LSiFX's sides
    LSi7's rears
    PS3
    Wii
  • dorokusai
    edited April 2007
    Don't let me discourage you, lead the way.
  • McLoki
    McLoki Posts: 5,231
    edited April 2007
    I have read a thread a while back of someone adding dynamat to the inside of his LSi speakers with good results in increased clarity. You might want to try that as a relatively cheap mod. I have been thinking about doing that to my setup, but then again, I am pretty happy with the sound I am getting now.
    Michael
    Edit - Found the link to the dynamat thread...
    edited April 2007
    dorokusai wrote: »
    +1. But just make sure and do some research. Most times experimentation is the key.
  • dorokusai
    edited April 2007
    McLoki wrote: »
    Michael
    I have heard in my travels that adding damping material to the actual port tube, is beneficial.....and its true.
  • McLoki
    McLoki Posts: 5,231
    edited April 2007
    dorokusai wrote: »
    Outside of the port tube I assume (since inside would change the port diameter)? I am still thinking about this mod at some point rather than trying to get new speakers - I am just that happy with my LSi's.
    Michael
