Leaving Amps on 24/7
  • Systems
    Systems Posts: 14,873
    edited April 2007
    RuSsMaN wrote: »
    Lightning is typically between 20,000 and 2,000,000 volts at anywhere from 10,000 up to 200,000 amps.
    It can't be stopped by off the shelf 'protectors'.
    Your link is talking about interior surges IN the building, ie its own devices failing. It has no talk about good ole mother nature.
    Cheers,
    Russ
    Yep, the best insurance and only 100% fail safe method is to pull the plug.
    Testing
    Testing
    Testing
  • unbridled_id
    unbridled_id Posts: 179
    edited April 2007
    Who makes this? Got a link?
    __________________
    www.pricewheeler.com
    The greatest enemy of truth is very often not the lie - deliberate, contrived and dishonest - but the myth - persistent, persuasive and unrealistic.
    Blaming the prince of the fools should not blind anyone to the vast confederacy of fools that made him their prince.
  • unbridled_id
    edited April 2007
    Wow, yes, so if lightning hits my house (that will be a problem enough on it's own), your saying that 200,000 amps is going to run through 12 g wire to my system? If if destroys the breakers how can it travel beyond that point? Educate me Russ because I don't quite get it. Do you mean a direct hit on my equipment, if that is the case then I totally agree, no surge protector, not even my brickwall will help.
  • TN_Polk_Lover
    TN_Polk_Lover Posts: 243
    edited April 2007
    The lightning can enter through the main electrical service entrance and jump right across the circuit breakers and into the rest of your house wiring. With voltages that high, it doesn't take much for it to jump. You may not even be getting the full jolt. Much of the jolt will bleed off to ground through the grounding that your electrical system has. But there can be enough left over through the rest of your wiring that it can certainly fry any type of surge protector.
    Robert
    You are officially in the high-end of the deep-end of the top-end.
    Bonus Room Over Garage:
    Toshiba 27" CRT TV
    Digital Source: Sony DVP-NS3100ES
    DVR: Panasonic DMR-ES15
    Denon 3806 AV Receiver
    - L/R Preamp out to Parasound HCA-1200 Amp
    Polk RTi70's, CSi40 Center, RTi38 Side Surrounds, RTi38 Back Surrounds
    Living Room: (2ch only)
    TV: Sony KV20-FV12
    DVD Player: Sony DVP-NS715P
    Yamaha R9 Receiver Polk RTi38's
  • Early B.
    Early B. Posts: 7,900
    edited April 2007
    OK, but what about when the power goes out? In my sub-division the power goes out frequently, ususally during storms due to trees falling on power lines. Is there any risk of having an amp plugged directly into the wall and OFF, but a blackout somehow ruining my amp?
    Thanks.
    "God grooves with tubes."
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited April 2007
    There is some risk when the power comes back on-line. The best protection against that is whole house surge protection. Call your utility company for more info, but mine will install them for free when you purchase the unit. About $500 last time I checked.
  • madmax
    madmax Posts: 12,434
    edited April 2007
    When the power goes out you can also get a really big spike. As for lightning, it is a VERY quick pulse which can get through the breakers for a long time at a very high voltage before they trip. We are talking microseconds of a very high voltage. No device works very well with something as quick as lightning. Often times even though the protection devices blow it is too late.
    madmax
    Vinyl, the final frontier...
  • ben62670
    ben62670 Posts: 15,969
    edited April 2007
    WilliamM2 wrote: »
    These do work very well, and like he stated your whole house is covered. These devices are designed to take the hit if lightning strikes more so than a surge when the power comes back on. Power surges from the power coming back on are very rare, and when they do happen they are typically not high enough to cause a problem.
    Ben
  • TN_Polk_Lover
    edited April 2007
    I guess it would depend alot on what type of wiring your area has. I would assume if you are in a subdivision with underground wiring, your chance of damage from lightning would be less than an area with above ground wiring.
    I remember when I was a boy going to visit my grandfather who lived in a small farm community in Southern Alabama. I guess because the wiring on the poles was pretty tall and the houses were kind of few and far between, there was much more likelihood of lightning hitting the power lines. I remember that my grandfather was all the time having to replace the heating element in his electric hot water heater, or one of the burner elements on the stove, because the lightning would sometimes zap them. Funny thing though, his old Philco B&W tv survived everytime.
    Robert
    Toshiba 27" CRT TV
    TV: Sony KV20-FV12
  • MSALLA
    MSALLA Posts: 1,602
    edited April 2007
    RuSsMaN wrote: »
    Cheers,
    Russ
    When I was a teenager lightning hit the backyard transformer. It fried EVERYTHING. TV's, stereos, surge protectors, the fridge,you name it. Nothing is safe from a lightning hit.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • hearingimpared
    hearingimpared Posts: 21,136
    edited April 2007
    Yes NOTHING can protect from a lightening strike. One thing I would like to make clear is I keep my gear always powered up, when a storm is brewing I unplug the whole kit and kaboodle and move the wires a few feet from the wall until it is all clear.
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited April 2007
    Yes NOTHING can protect from a lightening strike. One thing I would like to make clear is I keep my gear always powered up, when a storm is brewing I unplug the who kit and kaboodle and move the wires a few feet from the wall until it is all clear.
    But what if you are not home...? I always worried about that and I always left my amps on.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
    treitz3 Posts: 20,012
    edited April 2007
    RuSsMaN wrote: »
    Off, unplugged if there is a chance of threatening weather.
    There isn't a surge box out there that will stop a direct hit. NOT one. It will run straight through fuses and breakers, and cook everything in the path.
    I even make sure the cord is at least a foot away from the outlet, that kind of voltage can jump.
    True. Fact. Deal with it.
    Mother nature doesn't care about electronics.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited April 2007
    It will happen so fast, the breaker might not even trip, just fry to a crisp. If it does trip, it will jump right across it and keep right on going. It doesn't have to start at the breaker box either, a nice bolt through your roof into your attic - maybe it will start with your a/c unit or furnace - maybe it jump down through your satellite or cable tv wiring.
    It's powerful enough, all it wants to do is get to ground, and in-house electrical, and other wiring is a nice pathway.
    Cheers,
    Russ
  • ben62670
    edited April 2007
    I heard if you stand on your roof with a golf club during thunderstorms (Caddy Shack style) that you can defer the energy from lightning bolts away from your equipment.
    Ben
    billbillw Posts: 7,579
    edited April 2007
    Boy, I'm glad I have lots of tall trees around me! Hopefully they will present a better path to ground than my rooftop antenna.
    I never bother to unplug my gear. Its too hard to get behind it all! I mean my HT system wires can only be reached by crawling through a cubby hole. My 2 ch system I'd have to carefully move the 130lb Mirage from the one side, get down on my hands and knees, and then do my best stretch armstrong impression to reach the outlets!
    All this when I'm trying to get my family into our designated saferoom. Not going to happen! If it all goes in a blaze of lighting glory, so be it. That would be God's way of telling me spend more time with my family or do more community work.
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    ben too funny
    engtaz
    engtaz
  • wingnut4772
    edited April 2007
    billbillw wrote: »
    Must......reach.....power cords.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • ben62670
    edited April 2007
    Is that an original stretch Armstrong?
    Ben
  • wingnut4772
    edited April 2007
    ben62670 wrote: »
    I guess so. I just found the pic online. I used to have one as a kid though. (as the train flies of the tracks):p
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • ben62670
    edited April 2007
    If you stretch them to far they tear, and there was some sort of goo inside. I don't remember what it looked like, but it didn't taste to good. Anyway they gave you band aides with the toy:)
    Ben
    edited April 2007
    I don't care who U are, tha't FUNNY! (in my best Larry voice)
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2007
    ben62670 wrote: »
    No, that's Trey at his first Polkfest.
  • I-SIG
    I-SIG Posts: 2,243
    edited April 2007
    On a typical 12.47kV power distribution system even a vicinity strike can cause the voltage to spike to 38kV in a few hundredths of a millisecond. (10^-5)
    What does this mean to you? Even lightning arrestors, relays, and other equipment designed withstand these voltages and look for these events can only react in a few cycles (1/60 to 1/20 of a second).
    Therefore, yes, your breaker in the box may disintegrate it is still going to allow a massive spike in voltage and amperage through before it lets go. Even melting plastic and metal won't give that quickly short of a nuclear blast.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • I-SIG
    I-SIG Posts: 2,243
    edited April 2007
    WilliamM2 wrote: »
    Correct, especially if the power has been off for a few hours or more. It's what we call "cold load pick-up" and it can be a ****. It is much less of a problem if the break or recloser simply operates a time or two to clear the fault but there will still be a small spike and some transients from lots of equipment getting re-energized after being a 1/3-3 seconds.
    Wes
  • ben62670
    edited April 2007
    I have seen the whole house protectors as described above take the hit, and prevent the rest of the house from receiving damage. That being said the ground wire isn't/can't be protected by such a device. Power can still travel through the ground wires and destroy electronics, and appliances. But protecting the whole house is still the best bet. Unless you get a direct hit you will be covered.
    Ben
  • hearingimpared
    edited April 2007
    If I'm leaving for any length of time I always check the weather forcast. If there is the slightest hint of rain off everything goes and plugs pulled 2 ch rig, tvs, PCs, etc.
