Changing tweeters in a SRS2 speaker??
engtaz
What all needs to be done to change out the tweeters to RD0194. Do they solder on? Anything to watch out for?
Thanks,
engtaz
Thanks,
engtaz
engtaz
Post edited by engtaz on
unscrew from cabinet,, KEEP the gasket,,,blue/black = + (IIRC), insert into cabinet,, ,,do not overtighten screws,,,turn amp back on,, and you are done.
JC approves....he told me so. (F-1 nut) -
takes less than 5 minutes to do. so easy.. even I could do it.
PolkFest 2012, who's going>?
solder or slide on spades
engtazengtaz
slide on spades
I had to do all 8 of mine :eek: :eek:
cool
Thanks guy I thought it was like that but I needed to know if I had to take a solder Iron to the guys house
engtazengtaz
the ones that I have changed have been of the slide on type,,JC approves....he told me so. (F-1 nut)
What Tweeter does the RDO 0194 match in the other previous or current speaker lines?I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
MillerLiteScott wrote: »What Tweeter does the RDO 0194 match in the other previous or current speaker lines?
The SL2000.
At least those are the tweeters that are in my 2Bs currently, with the 0194's being the new upgrade.Wristwatch--->Crisco -
I am actually trying to figure out what it is comparable to more so than what it directly replaces.
Specifically how does the RDO 0194 match the tweeter in my CSi5?I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D -
is red positive on rd0194
engtazengtaz
yep the red terminal is positive on the rdo194-1JC approves....he told me so. (F-1 nut)
