rear speakers choice?
steelervic
hi, what should i use for rears in a 5.1 set up, fx500's or rt800's? i have rt2000i fronts and a cs350ls center.
thanks for your opinion!
Post edited by steelervic on
Try both and see what sounds best, Me personally it seems a waste to put a large 800 in the back unless your listening to 5 channel stereo all the time or something. But then somepeople don't like the fx style speakers for rears, they rather have direct fireing like me.. and also i assume you have space for proper placement of a large rt800 in the rear? things to think aboutMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
