WTB: 20 feet Monster Z2 Speaker Cable
RichCanDo
Any one have a spare 20 foot length? I'm going to use it to make an SDA IC cable. Some on eBay for $1.29 foot. Was going to order it but thought I would try here first.
Mains; SDA 1.2TL Silk Domes, upgraded xover, biamped w/DBX BX1 200wpc
Pre-amp: DBX CX1
Center: CS1000p Rear Surr.; f/x1000
Parasound HCA-1205A amp; Center & rear
Sub: SVS PB12-Ultra
DVD: Denon 3910
Tuner, FM: Onkyo Integra T-9090II
Cassette: Onkyo Integra TA-2090
VCRs: JVC HD4000U digital, HRS8000U SVHS
Signal Processing: DBX; 10/20 EQ, SNR-1, 120X-DS, 3BX-DS, DAV-600G Router, Onkyo EQ-35
Conditioning: Monster AVS2000, HTS5100MKII
Pre-amp: DBX CX1
Sub: SVS PB12-Ultra
DVD: Denon 3910
Post edited by RichCanDo on
try accessories4less.com,, I used some to make my sda interconnect cable, paid .99/ft,,Raife gives a very nice, almost step by step in one of his posts,which is how I made mine, good luck.:)JC approves....he told me so. (F-1 nut)
Might want to try ebay. It seems like you can get monster cable and wiring at pretty good price their.
I purchased a THX certified 18foot sub cable for my PSW1000 their for $.99 only catch was they charged me $19 for shipping. I still saved alot though. -
Thanks for suggestions. Best price on eBay so far is $1.29 per foot for new cable. I'll check out accessories4less.com. I plan to use Neutrik Speakon 90 degree connectors for my IC cable, unless I find a better smaller type connector & a jack that I can install in the binding post plate.Mains; SDA 1.2TL Silk Domes, upgraded xover, biamped w/DBX BX1 200wpc
Pre-amp: DBX CX1
Sub: SVS PB12-Ultra
DVD: Denon 3910
Conditioning: Monster AVS2000, HTS5100MKII -
I ordered the cable from accessories4less.com. Thanks for the tip George. Saved me $8.Mains; SDA 1.2TL Silk Domes, upgraded xover, biamped w/DBX BX1 200wpc
Pre-amp: DBX CX1
Sub: SVS PB12-Ultra
DVD: Denon 3910
