Bi Wire Jumpers
klove2
I hope i dont sound like and idiot but could some one please tell me the easiest way to remove the jumpers off off the speaker terminals. I am not sure if they slide out or do you have to remove the binding post. the Instructions that polk sends with the speakers are useless as far as removing the jumpers.
Set up
MONITOR 60S FRONT L/R
CS1 CENTER
R30S SURROUND L/R
SVS PB-10 SUB
YAMAHA 5740 RECIEVER
Set up
CS1 CENTER
R30S SURROUND L/R
SVS PB-10 SUB
Post edited by klove2 on
Not sure about those ones but usually just unscrew the top one and the top of the jumper swings out. You will probably have to totally unscrew the bottom one to completely pull of the jumper.Michael
NORTH of 60° -
What he said:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables -
Like Janmike and deadof_knight said unscrew the binding posts all together, the little plastic caps plugged to the Binding posts might fall off, just push them back in. Polk's Monitor series's "Manual" is a joke. (The speaker is great though)
