Vintage Polk Audio Parts - Crossovers & Misc.
dorokusai
dorokusai Posts: 25,576
edited March 2007 in For Sale (FS) Classifieds
Just real quick, before these get listed on eBay, does any one need the following:
Monitor 5jr - MINT Grills *GONE*
Monitor 5jr - Crossovers *GONE*
Monitor 7(Original) Crossovers - *GONE* BEN62670
Monitor 10(?) Crossovers - *GONE* F1Nut
MW6503 Driver(USED) - *GONE* BEN62670
**FREE**
Let's talk but these will be listed soon, if they don't sell....garbage.
Post edited by dorokusai on
  • dorokusai
    edited March 2007
    On second thought, you cover the shipping, this stuff is yours for the taking. I need it out the door.
  • John in MA
    John in MA Posts: 1,010
    edited March 2007
    I'd be interested in the 6510 (I think that's what my 11T's use) and the SL2000's as spares.
  • dorokusai
    edited March 2007
    John - I yanked those prior to my FREE offer, just so we're clear.....you still interested? If you are, I'll square you away nicely.
    heiney9 Posts: 25,396
    edited March 2007
    Mark, are the terminal cups from the 5jr's the same size as the 5b's? Are these from original 5 jr's or 5 jr +'s? Are they fused or poly switches? I'll take them as spares for my 5b's if they will work. I'm going to jump over to the troubleshooting forum and have a look see at the shcematics for all 3 (5jr's, 5jr+ and 5b's) and I'll get back to you.
  • DollarDave
    DollarDave Posts: 2,575
    edited March 2007
    [edit] wrong thread..
  • dorokusai
    edited March 2007
    H9 - Identical, 5jr, fused.
    edited March 2007
    dorokusai wrote:
    H9 - Same size, almost positive 5jr, fused.
    The inductors are a much different value in the 5 jr's. If no one claims them right before they head to ebay give me one last heads up.
  • ben62670
    ben62670 Posts: 15,969
    edited March 2007
    I sure could use the MW6503 Driver
    I could also use the model 7 XO
    Thanks Ben
    Ben
  • dorokusai
    edited March 2007
    Then you sure can have it.... dorokusai@comcast.net
  • dorokusai
    edited March 2007
    You said cups, the cups are identical. Correct, the inductors are different. Just clip the leads and spend $10 on a cheap Air Core....it's not like you won't have board space....as there is no board. I would upgrade the inductors anyways, there's only two and its pretty cheap. I can see the x-over nerds being cheap on a big SDA but when it comes to really doing a crossover right, and its this simple, gimme a break.
  • dorokusai
    edited March 2007
    Its simply copper wire on a spool, much like thread. The core is either inert or magnetic. They can be cheap and/or really expensive. It just depends on your motivation.
  • John in MA
    edited March 2007
    I think I'll pass for now, only needed spares. Thanks.
  • dorokusai
    edited March 2007
    That's good enough, thanks for helping me make some space guys!
