Mono Amplifier..
TennesseeOutlaw
TennesseeOutlaw Posts: 414
edited April 2007 in Wanted (WTB) Classifieds
Something like a Marantz MA500 or MA6100.. Or a Outlaw Audio Mono-block.. Any other suggestions out there?
Post edited by TennesseeOutlaw on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited March 2007
    There are a lot of good stereo amps that can be bridged mono. What's the application, budget, and power requirements?
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2007
    I have a pair of Denon POA-4400 monoblocks. Old school, well built and the amps can be individually bi-amped which is neat.
  • TennesseeOutlaw
    edited March 2007
    For a center channel.. Id like to stay around 150.00 bucks..
  • dorokusai
    edited March 2007
    I'm out but good luck. I'd look for a used Outlaw M-200.
  • RuSsMaN
    edited March 2007
    You can pick up a new Audiosource AMP-100 for around $110 shipped on ebay and various other sites. It's a stereo amp, 50x2 cont, rated on paper to 100w bridged mono - but on the bench they will hit around 137w cont before the wheels start to shoot off.
    I had 3 of these amps in my whole house rig for about a year, with no issues. Good, solid, cheap power.
    Cheers,
    Russ
  • dorokusai
    edited March 2007
    I always forget about that manufacturer, great choice.
  • TennesseeOutlaw
    edited March 2007
    Do they make one that has just a little more juice? Id be willing to up my spending a bit for some more power..
  • TennesseeOutlaw
    edited March 2007
    N/M.. I just found it.. Thanks for the heads up..
  • TennesseeOutlaw
    edited March 2007
    Which would you recommend the highest? AudioSource Amp200, Outaw Audio Mono Block, or the Marantz MA500?
  • RuSsMaN
    edited March 2007
    The Outlaw has a good lineage, from GAS and SAE. Marantz knows amplifiers, and is always a solid choice. Audiosource is owned by Phoenix Gold now, a long time player in the 12v amp world.
    As far as I'm concerned, take your pick.
  • TennesseeOutlaw
    edited March 2007
    One more ??? What is the difference in the Amp200 and the Amp One/A? It has the same specs, but I can get the Amp One/A for about 75.00 bucks cheaper.
  • RuSsMaN
    edited March 2007
    The 'hundred' models are the current lineup, the one/a is a discontinued model.
  • Systems
    Systems Posts: 14,872
    edited April 2007
    Well?....have you decided?
    Testing
    Testing
    Testing
