Bannana plugs for Monitor 5B
ANWKLO
ANWKLO Posts: 173
edited March 2007 in Vintage Speakers
Can the bannana plugs be firmly connected to the Monitor 5B? Thanks.
Post edited by ANWKLO on
  • michael_w
    michael_w Posts: 2,813
    edited March 2007
    I use acoustic research nanners and have no problems hooking them up to my monitor 7's that use the same terminal cup (from the looks of it). It varys from plug to plug how tight the fit will be, but for the most part they're fairly universal.
  • avguytx
    avguytx Posts: 1,628
    edited March 2007
    Banana plugs work on my 10B's with no problem. That appears to be almost the same terminal cup sans fuse holder. The plugs look the same...but like anonymouse said.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
    heiney9 Posts: 25,451
    edited March 2007
    Yes........
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2007
    Yes.
    edited March 2007
    dorokusai wrote:
    Yes.
    So you concur.
  • dorokusai
    edited March 2007
    Aye.
  • Polk65
    Polk65 Posts: 1,405
    edited March 2007
    doro is prom-iscuous.
  • michael_w
    edited March 2007
    I couldn't resist. Sorry Mark.
  • dorokusai
    edited March 2007
    LOL
    Holy crap, look at my neck! At least you picked a semi-sober picture....whew :D
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited March 2007
    Mark is sort of sexy with long hair.
  • michael_w
    edited March 2007
    I figured the little half-smile was fitting to keep it close to the original. For some reason I don't think this is the first time Russ has seen 'Mark gone nelly'? Think of it as a Troy-esque mask ;)
  • dorokusai
    edited March 2007
    I look like the drunk redneck version of Robert Plant in the 80's.
