Adcom amps
powerlord
powerlord Posts: 310
edited March 2007 in 2 Channel Audio
I'm looking at a few of these right now,a couple 5802's or a 5500.I will be buying one amp for my mains and let my reciever take care of the surrounds.For the money these have quite a bit of power.Anyone have any experience with these and can I go wrong here?
LG 50 in. Plasma
Eosone setup
Marantz SR-18U
HK AVR-7200
My Music
http://members.soundclick.com/powerlord66
Post edited by powerlord on
«13
  • danger boy
    danger boy Posts: 15,722
    edited March 2007
    first off.. everyone in here has their "favorite" brand of amp... i do, he does, she does.. etc. for good bang for your buck... the Adcom amps will serve you well.. if you're looking to save some bucks... you may want to consider buying used Adcom amps.. if you buy new... Adcom has a trade in program where you can upgrade to another one of their amps later on down the road. not a bad deal huh?
    have a nice day!
    PolkFest 2012, who's going>?
  • powerlord
    edited March 2007
    Yeah I did a search and the comments on these amps were pointing toward the mediocre side,I'm just getting my feet wet in the seperates and don't want to spend an extreme amount of change,I was looking on the bay and found pretty reasonable Carver and Adcoms.
    LG 50 in. Plasma
    Eosone setup
    Marantz SR-18U
    HK AVR-7200
    My Music
  • snow
    snow Posts: 4,358
    edited March 2007
    Well I dont know what they were comparing them to but adcom amps are not mediocre by most standards lol. I guess pretty much anything can be called that if you compared them to something that costs a lot more. But i think that as bang for the buck there hard to beat if you buy used. plus you can always upgrade if you dont like it. Theres always someone looking for an adcom GFA-555 GFA-565 mono block etc. wish I had a hundred of them. I know i could always sell them.there like money in the bank. REGARDS SNOW
  • ben62670
    ben62670 Posts: 15,969
    edited March 2007
    Wanna buy a sunfire?
    Ben
  • engtaz
    engtaz Posts: 7,669
    edited March 2007
    go for it they are great amps and great sounding.
    engtaz
    engtaz
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited March 2007
    there OK. Many others around the same price to choose from, everyone has to start somewhere, just get something with high current to start with. The amp is just one part of the entire system.
    RT1
  • powerlord
    edited March 2007
    My budget is around the $600 level right now,I would love a Sunfire for a starter.I've heard my RSF1000's will really wake up when pushed with more than 200 wpc clean:)
    LG 50 in. Plasma
    Eosone setup
    Marantz SR-18U
    HK AVR-7200
    My Music
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2007
    Look for Adcom's with Musical Concepts mods/upgrades on them. The don't pull in that much more than the stock Adcoms but the difference with the mods are far from mediocre.
  • powerlord
    edited March 2007
    How about Hafler or audio research?Saw a Hafler that kicks out 325 wpc at 8ohm,are these on the up?
    LG 50 in. Plasma
    Eosone setup
    Marantz SR-18U
    HK AVR-7200
    My Music
  • snow
    snow Posts: 4,358
    edited March 2007
    there is one hafler the XL600 that puts out 305 wpc into 8 ohms which is a pretty nice amp for the money that it usally commands . $450.00 or so average. Audio research makes very nice stuff but can be costly.
    REGARDS SNOW
  • powerlord
    edited March 2007
    I also spyed a Carver TFM-55X on the bay and was wondering how it stacked up to the adcoms.Shows quite a bit of power rating for such a light amp.
    LG 50 in. Plasma
    Eosone setup
    Marantz SR-18U
    HK AVR-7200
    My Music
  • ben62670
    edited March 2007
    Light amps = small or switching power supply, and small capacitors = waste of money. IMO
    Ben
  • cfrizz
    cfrizz Posts: 13,415
    edited March 2007
    People rave about their Carver's & Sunfire's. I like not giving myself a hernia if I have to move it & it sounds great!
    Like it or not, these lighter amps are most likely the future direction of amplification.
    So go for it Powerlord.
  • powerlord
    edited March 2007
    Wow, bold statement,I did a search here on the forum about Carver and most opinions were that it's great gear for the money,just didn't find anything on this amp
    LG 50 in. Plasma
    Eosone setup
    Marantz SR-18U
    HK AVR-7200
    My Music
  • powerlord
    edited March 2007
    Thanks cfrizz!
    LG 50 in. Plasma
    Eosone setup
    Marantz SR-18U
    HK AVR-7200
    My Music
  • cfrizz
    edited March 2007
    My pleasure Powerlord.
    As you can see there is a HUGE difference of opinion when it comes to amplification. Some comes from knowledge, some comes from specs, some comes from elitism.
    All of it is subjective, and as with every thing else in life there is a low end a middle end & a high end.
    I try to stay in the middle recommending what I have personal knowledge of & what will give most mid hifiers the best bang for their buck and maximizing the improvements to their systems.
    It's worked for me, I figure it can work for others as well.:)
  • powerlord
    edited March 2007
    Yeah, mine is a budget limit,so I'm going to have to get what I can afford and I'm trying to be real careful with what I buy so that I'll be happy with my purchase.So far the reviews of the adcoms and Carvers are pretty good,I've also seen some budget Parasound amps,the Carvers would be ideal because of their room saving quality.It's pretty much hit and miss with used gear and being new to seperates I have virtually no idea of what I'm looking for,I'm basically going to listen to you guys on this as I have no resources to speak of where I live.CC,BB and Ultimate don't offer much in the real world amp advice dept.I appreciate your advice.And I'm sure I'm going to be hooked on seperates after my introduction to them after the night and day differences I hear about so much versus the reciever.
    LG 50 in. Plasma
    Eosone setup
    Marantz SR-18U
    HK AVR-7200
    My Music
  • engtaz
    engtaz Posts: 7,669
    edited March 2007
    Outlaw Audio makes good amps and budget friendly.
    engtaz
  • cfrizz
    edited March 2007
  • powerlord
    edited March 2007
    Ya know frizz,a guy that owns a shop here and is an authorized Rotel dealer brought over a Rotel 1080 and we compared the sound from my reciever and he and I came to the conclusion that there wasn't enough difference to consider buying his amp,we then went to his house and we listened to the same amp on his smaller speakers and they were phenominal,I think his mains were Ascends or Ascents and they weren't martin logans,they were quite a bit smaller than my mains though.So he said I should look for something in the 300 plus wpc, thus the eyeballing of the Carvers.Supposedly my mains are juice hogs so the more the merrier some say about them.I could probably produce up to 700 bucks for my amp but no more.And thanks for the heads up there on the gon.
    LG 50 in. Plasma
    Eosone setup
    Marantz SR-18U
    HK AVR-7200
    My Music
  • snow
    snow Posts: 4,358
    edited March 2007
    go here if you want info on the carver.
    http://www.carveraudio.com/phpBB2/index.php
    REGARDS SNOW
  • powerlord
    edited March 2007
    Thanks Snow,I didn't even know that existed.
    LG 50 in. Plasma
    Eosone setup
    Marantz SR-18U
    HK AVR-7200
    My Music
  • cfrizz
    edited March 2007
    Wow! Happy hunting!:)
  • vonnie123
    vonnie123 Posts: 326
    edited March 2007
    Adcoms are great amps. I have a 16 year old GFA-555 still providing great service.
    F1nut Posts: 51,766
    edited March 2007
    A few things to consider. You were still using your AVR as the pre amp, so that can be a limiting factor as to how much of a difference a power amp will make. Your AVR, speakers and the Rotel may have not had synergy while his set up did. WPC are not the end all. You could easily find that a 70 wpc amp sounds the best because it has synergy with your set up.
  • powerlord
    edited March 2007
    Point taken F1nut,buying used gear could be a costly experiment though trying to find an amp that works.I have a guy coming over today to let me audition his adcom 5800 on my system,I'll let you know how it goes.And thanks again everyone for the schooling.
    LG 50 in. Plasma
    Eosone setup
    Marantz SR-18U
    HK AVR-7200
    My Music
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited March 2007
    I have a Carver TFM 55x and an ADCOM GFA 555 MK II. I am happy with both. You should be happy with them until you befriend someone with better equipment. This will happen and you will be on the hunt again.
    Good luck,
    Steve
    :eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More" :D
    Sony cx985v (for now)
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    AudioQuest Crystal 2 spk wire
    Nordost RCA
    SDA 3.1 tl RD0 tweets
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
    VMPS Original Tall Boy (Mega Woofers soon)
    heiney9 Posts: 25,432
    edited March 2007
    Powerlord,
    All the advice given is solid as well as all the amps mentioned. If this is your first foray into seperates there have been several good ideas. What is your final goal? What F1 says, is VERY true, you will be limited by your AVR as a pre amp and eventualy by your source. If you are wanting to build a solid 2-ch system down the road then perhaps a little more care and research into what amp will suit you in the long haul. If you are looking to bump your power and improve the sound of your current set-up (HT) then the Carver or Adcom or Sunfire or Parasound.........is a great choice.
    I am biased towards Adcom because they are plentiful, easy to re-sell, and sound great for the $$$. I've had a GFA-545 for 20 years and it still sounds great today. The 555 was the single most popular amp in history so there are a lot of them still around. They rarely break unless of severe stupidity. They are simple and straight forward designs that hold up and sound great.
    Synergy is key as some will tell you Adcoms or Carver or Sunfire is this or that. Only way to know for sure is to buy something and try it out. I have my opinions on a lot of gear and it may or may not be what you or anyone else nec. agrees with. Be careful of taking too much opinion on the internet as fact.
    As a side note I started to believe certain things(after using the amp for 20 years) about Adcom's (negative things) based on internet opinion, but when I actually did some comparison's I found, IMHO, that most of it was untrue (atleast in my system, in my room, with my other components).
    Did I mention synergy between components is key. :)
    Also read my sig...........that's what this hobby is all about.
    edited March 2007
    Please do. It's always refreshing to hear from someone who isn't jaded about this kind of thing. You are new to this seperates thing so you have very little if any preconcieved notions.
  • ben62670
    edited March 2007
    I think you are going to love that amp. If you have dire straits Brothers in arms put that on. Track 2, also track 5 to test for smoothness. If your not interested let me know if he wants to ship it.
    Ben
    Ben
