Opinions-suggestions?
BAD ASP
straight up which pre would you suggest if the price for used units was identical between the Sunfire theater IV or the Krell showcase 7.1. Any advice or suggestions would be greatly appreciated
mike
mike
Amp: sunfire cinema grand signature 5ch 425 wpc
Side surround amp: Sunfire 2 X 300
Processor: sunfire theater grand V
Fronts:: polk sda-srs 1.2
Rears: Polk LSiFX
Side surrounds: Fxi5
Center: (2)polk LSiC's
Sub: svs pb-13 rosenut
Hd-Dvd: toshiba xa-2
Blue Ray: oppo bdp83se
Projector: sony vw60
Screen: Da-Lite 106"
APC S20 Power conditioner
Rears: Polk LSiFX
Post edited by BAD ASP on
Krell
krellWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
Krell
thanks, I'm beginning to get the message.Home Theater
Rears: Polk LSiFX
