Amplifier Help Required
ShaamiE
Hi, I've recently installed a pair of MMC 690 and db 650 in my new honda. I hooked the system directly with a Kenwood head unit. I need some help in selecting the right Polk amplifier for my system which can give me further depth,clarity and listening pleasure. I intend adding up a subwoofer but not in near future.
Post edited by ShaamiE on
Well the choice is pretty simple, as Polk only has one 4ch amp. By the way, any quality amp will give you what you are looking for, specially when compared to the power from a HU.
The Polk C400.4 is a good choice. Here is the link to it:
http://www.polkaudio.com/caraudio/products/c400_4/Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
Thank u very much for ur advice Blackmax
I hope the speakers would be a perfect match as far as technical requirements are concerned. Im in interested in getting a newer head unit. I have heard Alpine head units are deliver amazing sound with or without amps. Id be grateful if u can recommend some Alpine head unit too.
best regards
ShaamiE -
No problem
What functions do you want in a HU? Alipine makes good HU's, but their latest offerings leave much to be desired in the way of processing. I am actually waiting to see the CDA-9887 that is coming out in the summer. This unit will have the processing abilities that have been missing from their line up in the last couple of years.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
dude... Audiobahn A6004V -- 75 x 4 @ 4 ohms, and its only about $120 bucks new online... whereas the 400.4 is in the 300 range online last i sawThe Artist formerly known as PoweredByDodge
