My opinion CS350ls vs. CS400i
hoosier21
hoosier21 Posts: 4,420
I bought a CS350ls based on many here using it with the older SDA speakers and that they were very happy with it. But I was not as thrilled with it, it did not come close to matching the sound in the higher feq. as would have liked. I sold it and bought a CS400i and I really like the match much better, not perfect but MUCH closer, the CS400i is a big mother, but works great and can handle what I have give it so far. I have set mine to small, is anybody using it as LARGE?
My 2 cents worth
Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
  • wangotango68
    wangotango68 Posts: 1,056
    edited November 2001
    i have mine set to large and the 2b's set to large also
    scott:cool:
  • rskarvan
    rskarvan Posts: 2,374
    I think my Denon 3801 handles the CS400i better when
    set to small. If I were powering the CS400i from an
    external amp, I would set it to large.
  • PETERNG
    PETERNG Posts: 915
    I still like the performance of the CS350LS, I move it to my bedroom after I bought the CS1000p for the living room, I think the CS350LS is one of the best center channel speaker in the market, beautiful craft and design, and I probably won't plan to replace it for a very long..long time.
  • juice21
    juice21 Posts: 1,866
    my 400 is set to small, i find it easier to manage the bass with it set this way. i am looking to upgrade to external amps, and i will probably have to play around again to see what sounds better then.
  • Aaron
    Aaron Posts: 1,853
    Just remember that when you set the speaker to large you're no longer allowing the sub to pick up the lower frequencies of the center channel. This is a three-fold disadvantage, because 1) you're requiring a weak receiver to drive the speaker full-range, stripping precious power away from the receiver, 2) forcing the speaker to produce "full-range" sound will degrade the sound quality (and the center is where you'll notice it most), and 3) you're losing out on any low bass from the center channel because the speaker can't really produce meaningful bass below 45Hz. (while the sub can).
    Aaron
  • RuSsMaN
    RuSsMaN Posts: 17,985
    ...Just curious, what speakers do you have that hit 10Hz? I imagine they must have a very large cabinet to get that low.
    Cheers,
    Russ
  • RuSsMaN
    ...spared no expense eh?
    Well, I guess if a speaker system cost $130K+, and weighs in at over a TON, it BETTER hit 10Hz.....
    Jeez.
    Russ
  • RuSsMaN
    What are you driving them with? I take it this is NOT part of an HT rig.....
    I could care less how you got em, really....thats your business.
    Russ
  • RuSsMaN
    One hell of a rig, must sound Amazing .
    I've heard some nice Krells on B&W rigs, but never a ribbon.
    Cheers,
    Russ
  • CHRIS
    CHRIS Posts: 454
    R
    Yeah the Radio Shack Optimas are a great speaker. I do think they should come down in their price but what can you do.
    Chris
    Chris :)
