Need a new center
Schlotkins
Schlotkins Posts: 3
edited March 2007 in Speakers
Good morning-
I need to do a major speaker upgrade down the road, but I'm moving for sure in less than 15 months and my current room doesn't really have the right setup for a 5.1 system. Thus, I'm running a 3.1 system and want to wait to get a complete package after I move.
In any case, I current have some 7 year old Polk RT55i's for the L/R channels and a CS245i for the center. To be honest, the CS245i is just not doing it for me - it's got a muddy unclear sound and it's hard to get clear dialog out of it. At the moment, I have it under my plasma on a shelf which isn't the optimal placement. However, even before that, the speaker was just not that great. So, I have two questions:
1) How bad would the mismatch be if I replaced the CS245i w/ the CSi5?
2) Does the CSi5 have the same muddy/unclear sound of the CS245i? From my understand, the new center is much improved.
I could also go with the LSiC if that would be a better option. I know the CS400i would be a better match, but (1) it's too high for my shelf and (2) I've read it has many of the properties I don't enjoy on my current setup.
Thanks for any advice!
Chris
Post edited by Schlotkins on
  • VSchneider
    VSchneider Posts: 443
    edited March 2007
    Welcome, Chris! I am glad you followed my advice and found your way here. I won't repeat myself (since you already have my opinion) but let's see which way the more senior members will steer you.
    - Val
  • danger boy
    danger boy Posts: 15,722
    edited March 2007
    true the CS400i would be the correct match for the RT55i's... but it's to big for your set up. I've found that as long as you stay with the same brand of speakers.. you should notice little if any sound quality difference in your center channel speaker of your fronts.
    I'd say, go with the largest Polk Audio speaker that would work for your set up.. so if that's the CSi5, then go with that one. also you need to calibrate your speakers with a Radio Shack SPL meter. that will also make a huge difference in how well you hear the center channel dialog.
    What receiver are you running?
    PolkFest 2012, who's going>?
  • Schlotkins
    Schlotkins Posts: 3
    edited March 2007
    Thanks for the replies. My receiver is a Denon 2807. I'm running a Toshiba HD-DVD player via HDMI to the receiver. According to the specs, I should be able to fit any of the current Polk centers in my setup as they are all shorter than the CS400i. The CSi5 looks like quite the monster.
    My major compliants with the CS245i is the lack of clarity in dialog and the limited sound stage. If I am off center very much, it's very difficult to hear anything.
    Thanks for your help,
    Chris
    edited March 2007
    If space is an issue,try no center and run the dialog thru the 55's,sure they will sound great and put the money towards upgradeing a cdp or surround
    speakers.Just a thought...try it.
  • engtaz
    engtaz Posts: 7,669
    edited March 2007
    Polk CS2 (2 - 6.5 & 1 - tweeter) is not huge but should complement your speaker. *bay sell them for 179.00 everyday.
    Good Luck,
    engtaz
    engtaz
  • AndyGwis
    AndyGwis Posts: 3,655
    edited March 2007
    If price isn't an issue, the CSi5 would seem to be the best option for you as I found my CSi3 to be crystal clear, especially when given good power.
    That's what I would go with if I were you. I have the CS2 now, and actually think the CSi3 was as good if not better (even though it's smaller, cheaper, and not a timber match). The CSi5 would be even better.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • fbwinners
    fbwinners Posts: 26
    edited March 2007
    CSI-5, I own one and I wouldn't trade it, dialogue is awesome from this center channel.
    FB
    TV - TOSHIBA 47LZ196
    FRONTS - RTI10'S
    CENTER - CSI5
    SUB - PSW 404
    SURROUND - RC8OI
    AV RECEIVER - ONKYO TXSR 804B
    HDDVD - TOSHIBA HDA2
    SACD/CD/DVD CHANGER - YAMAHA DVC6770
  • MSALLA
    MSALLA Posts: 1,602
    edited March 2007
    The Csi5 is a good speaker. It will also leave options to upgrade if you want when you move.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • Schlotkins
    Schlotkins Posts: 3
    edited March 2007
    Thank you for all of the replies. I'm going to evaluate the CSi5 and also consider if I want to do my big upgrade on the front 3 now or not.
    Thanks again,
    Chris
