Drilling a hole in Cultured Marble?
disneyjoe7
disneyjoe7 Posts: 11,435
edited March 2007 in The Clubhouse
As anyone done this? Looking to add a cable outlet, but wish to do it with a low voltage single gang outlet box. I have an existing 120vac outlet that will be ~4" or so from this hole, so I know it can be done but how?
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
  • BIZILL
    BIZILL Posts: 5,432
    edited March 2007
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • audiobliss
    audiobliss Posts: 12,518
    edited March 2007
    Or just grab your favorite bit, and some of your wife's diamond jewelry that you resent spending that much money on, and go to town.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • BIZILL
    BIZILL Posts: 5,432
    edited March 2007
    no, or else he'll need a dick splint.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • ledhed
    ledhed Posts: 1,088
    edited March 2007
    Any decent heavy duty masonry bit should do the trick. Remember though that you will probably need to be supplying water to the bit while drilling.
    God shows his love for us in that while we were still sinners, Christ died for us. - Romans 5:8
  • disneyjoe7
    edited March 2007
    How about making straight line cuts for an electrical box?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    edited March 2007
    LOL :D
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • BIZILL
    BIZILL Posts: 5,432
    edited March 2007
    diamond disc cutter. ledhed, masonry/concrete bit for marble? masonry bits are usually used in conjunction with a hammer/drill. but i don't see a masonry bit cutting nor drilling marble. but i could be wrong. or not.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • ledhed
    ledhed Posts: 1,088
    edited March 2007
    I'm just assuming a heavy duty one would be diamond tipped though I could be wrong.
  • BIZILL
    BIZILL Posts: 5,432
    edited March 2007
    if it's diamond-tipped, yes. but what do i know?
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • ledhed
    ledhed Posts: 1,088
    edited March 2007
    Probably more than some 18 year old punk :p:D
  • schwarcw
    schwarcw Posts: 7,358
    edited March 2007
    How thick is the marble? I wouldn't use a hammer drill on something that could easily crack and cost a buck to replace. Call a place that rents tools, they usually sell the bits for the commerical equiment. Get a recommendation, then shop around for the bit.
    Carl
  • read-alot
    read-alot Posts: 812
    edited March 2007
    It's Cultured Marble, there is a big difference guys.
    polkaudio SRS (rdo194 x 8)
    Dodd ELP (separate power supply)
    JC 1 blocks ( strapped )
    Rega Apollo
    MIT (speaker cables) Outlaw (ICs)
    polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • mwh9
    mwh9 Posts: 51
    edited March 2007
    A good masonry drill bit should be fine, as far as cutting the square hole if that is what you want, have you thought about using a jig saw or something like that with a blade that looks like it has grit like sandpaper instead of teeth. You should be able to get one at a local hardware store and it may say that it is for steel cutting but, it should be fine for what you are doing. If you use the masonry bit, use it in a regular drill, not a hammer drill.
  • Systems
    Systems Posts: 14,873
    edited March 2007
    Save yourself some grief and money. Trot on down to your local marble / stone countertop shop. Ask nicely and they will cut / drill any hole you need. A small investment in some doughnuts as a trade will get you far. You'd be surprised.
    Testing
    Testing
    Testing
  • disneyjoe7
    edited March 2007
    Hmmm.... that would be a house call this is the back wash area. My neighbor and house is in a nice area and all house calls are price + if you know what I mean. I think anyone how comes here just think I drip $$. Ha Ha.
    Thanks all you've all inspired me the try it. :)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • beardog03
    beardog03 Posts: 5,550
    edited March 2007
    Get the right Tips/blades and take your time...
    Bizill`s idea is a good one..diamond bits..
    Call your local marble shop , or even a contractor that does that type of work and ask the what bit/cutter they would use...
    remember...lot`s of water and steady / slow get`s her done
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • janmike
    janmike Posts: 6,146
    edited March 2007
    One question. What is the cost if it done wrong. Just a question.
    Michael ;)
    NORTH of 60°
  • read-alot
    edited March 2007
    Rega Apollo
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • disneyjoe7
    edited March 2007
    Thinking $5 give or take, 1 planter of ferns. ;)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • audiobliss
    edited March 2007
    Waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa!!!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • janmike
    edited March 2007
    At that price I should grab a dozen or so.
    Michael ;)
    NORTH of 60°
  • disneyjoe7
    edited March 2007
    For what do you think I Fup everything?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    edited March 2007
    Read-alot,
    Thanks for the link it's helpful. :)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • read-alot
    edited March 2007
    Steve,
    Glad to help, I did a remodel of our guest bath with cultured marble.
    I was able to visit the manufactor and watch it being made, trick stuff.
    Rega Apollo
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • janmike
    edited March 2007
    No at all. Just proposing questions. Give er.
    Michael ;)
    NORTH of 60°
  • BIZILL
    BIZILL Posts: 5,432
    edited March 2007
    didn't read the link read-alot posted, but when using diamond bits or wheels, the trick is super-high rpm's.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited March 2007
    I just used a carbide grit hole bit on a "fake rock" sink and it said on the package that it would cut marble.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • TN_Polk_Lover
    TN_Polk_Lover Posts: 243
    edited March 2007
    This may be a stupid question, but what makes marble "cultured"? What is the difference in "regular" marble and "cultured" marble? Thanks,
    Robert
    Robert
    You are officially in the high-end of the deep-end of the top-end.
    Bonus Room Over Garage:
    Toshiba 27" CRT TV
    Digital Source: Sony DVP-NS3100ES
    DVR: Panasonic DMR-ES15
    Denon 3806 AV Receiver
    - L/R Preamp out to Parasound HCA-1200 Amp
    Polk RTi70's, CSi40 Center, RTi38 Side Surrounds, RTi38 Back Surrounds
    Living Room: (2ch only)
    TV: Sony KV20-FV12
    DVD Player: Sony DVP-NS715P
    Yamaha R9 Receiver Polk RTi38's
  • read-alot
    edited March 2007
    Produced under artificial and controlled conditions = Cultured
    Rega Apollo
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • TN_Polk_Lover
    edited March 2007
    Oh, OK, I see, just like "cultured" pearls are real pearls, but the oysters are raised in a "farm" and they insert a piece of sand in them to start the process, as opposed to "natually" occuring pearls. Thanks for the explanation.
    Robert
    Robert
    Toshiba 27" CRT TV
    TV: Sony KV20-FV12
