Sound Meter
I just ran the Auto-Speaker Setup on my Onkyo 804. I found that I still had to tweak the speaker configuration manually. I would like to measure the test sound level and retest the system. What's the best sound meter to use as this is my first HT setup? Is there anything in particular I should be looking for?
Setup:
L&R RTI6
Center CSi5
Surround L&R RTi4 on Sanus stands
Sub PS12
DVD Denon 1930C
Thanks,
CTG
Post edited by controltestguy on
  • ben62670
    ben62670 Posts: 15,969
    edited March 2007
    Radio shack has a digital for $50. Set it for c weighting, and slow response. That should get you where you want to be.
    Ben
  • TN_Polk_Lover
    TN_Polk_Lover Posts: 243
    edited March 2007
    Hello, and welcome to the Polk Forum. Radio Shack sells 2 models, one analog and one digital. I think that the digital is about 10 to 15 dollars more than the analog. Either one will do fine. I bought the digital one and it has worked great for me. The digital one is $49.00.
    It is showing out of stock right now on their web site, but I think that all of their retail stores also carry it.
    http://www.radioshack.com/product/index.jsp?productId=2103667&cp=&sr=1&origkw=SPL+meter&kw=spl+meter&parentPage=search
    Robert
    You are officially in the high-end of the deep-end of the top-end.
    Bonus Room Over Garage:
    Toshiba 27" CRT TV
    Digital Source: Sony DVP-NS3100ES
    DVR: Panasonic DMR-ES15
    Denon 3806 AV Receiver
    - L/R Preamp out to Parasound HCA-1200 Amp
    Polk RTi70's, CSi40 Center, RTi38 Side Surrounds, RTi38 Back Surrounds
    Living Room: (2ch only)
    TV: Sony KV20-FV12
    DVD Player: Sony DVP-NS715P
    Yamaha R9 Receiver Polk RTi38's
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited March 2007
    Get a meter, as suggested - and get a dedicated HT setup / calibration DVD. I think the consenus around here is Avia, if I'm not mistaken.
    I'm calibrated, but I still find myself tweaking the center, and sometimes the surrounds on certain films.
    Cheers,
    Russ
  • TN_Polk_Lover
    edited March 2007
    As Russman suggested, a calibration DVD can be very helpful. I have the Avia one. It also comes with 3 colored plastic filters that you use to calibrate your TV (monitor) screen.
    I did read somewhere that Avia is coming out with a newer version. The one I have is a liitle dated and only does 5.1 setups. It does not have signals for 7.1 setup. There is also another one called Digital Video Essentials which a lot of people seem to like.
    Robert
    Toshiba 27" CRT TV
    TV: Sony KV20-FV12
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited March 2007
    Same meter as RS, but cheaper and in stock.
    http://www.bswusa.com/proditem.asp?item=SLM100
  • PSOVLSK
    PSOVLSK Posts: 5,373
    edited March 2007
    I have AVIA and a digital SPL and I'm happy with them...although I've read that the analog is better.
    Dennis: Wish I'd have known about this before I bought mine. Great link.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2007
    Welcome to the Club, RAT Shack SPL meter is the way to go. I have the analog model but I don't think they sell that one anymore.
  • janmike
    janmike Posts: 6,146
    edited March 2007
    Is the analog better or just different. I have the digital and am very happy. Personally I think it would be a personal preference.
    Michael ;)
    NORTH of 60°
  • ben62670
    edited March 2007
    I kinda like the digital, because you can set it at slow response, and set it for max SPL.
    Ben
  • hearingimpared
    edited March 2007
    I grew up on analog so it's really just a preference . . . you can set the analog for slow response too.
  • ben62670
    edited March 2007
    I learned something this evening:)
    Ben
  • engtaz
    engtaz Posts: 7,669
    edited March 2007
    I'll never grow up and bumps in life alway enhances my learning. Ha Ha
    engtaz
    engtaz
  • louthewiz
    louthewiz Posts: 581
    edited March 2007
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
  • hearingimpared
    edited March 2007
  • TN_Polk_Lover
    edited March 2007
    I bought my digital one about 2 months ago, and they still had the analog one also. I like my digital one.
    Robert
    Robert
    Toshiba 27" CRT TV
    TV: Sony KV20-FV12
  • PSOVLSK
    edited March 2007
    When I was looking for info last year before buying, most everything I read said to go with the analog meter, thus my earlier comment. I've been happy with my digital and my thought was always that it would be personal preference. I'm glad to see others have the same opinion...and I hereby retract what I said about analog possibly being better.
    Nice links Lou. I always enjoy learning a little more.
  • Gaara
    Gaara Posts: 2,415
    edited March 2007
    I thought the only reason the analog was better because it was easier to see differences. The digital rounds to the nearest .5db, whereas the analog you can discern smaller differences.
    Jared
  • hearingimpared
    edited March 2007
    Analog is always better than digital.:eek: :D:p;)
  • engtaz
    engtaz Posts: 7,669
    edited March 2007
    Very fast delevery.
    engtaz
    :):):D:D:):)
    engtaz
