optical vs. coax digital input
Even a half-assed POS digitalcoax with a decent shield is immune to picking up stray signals.
Coax sounds better to my ears, on my rig. -
Landry
FWIW, I found after running each for 4-6 months at a time, the following:
Toslink: Very neutral, almost sterile. Very deep/controlled bass. Smooth midrange treble at high volumes. Black background. Soundstage depth a little compressed compared to coax/XLR.
XLR: Warm, smooth character; more air around instruments. Bass a touch less controlled than Toslink. Treble the slightest bit more presence. Deeper soundstage. More of an "analog" sound to it than the other 2.
Coax: Smack dab in the middle between XLR and Toslink
The cables used were:
Toslink: quartz glass fiber optic from Sonic Wave, .5 mtr
XLR: Signal Cable AES/EBU digital, 2ft
Coax: DH Labs D-75, 1mtr
Bottom line:
Toslink: for the "accurate" music lover
XLR: for the "beautiful" music lover
Coax: for someone who wants a little of both, but compromises slightly on the best that Toslink/XLR have to offerSource: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Damn, ya think he is still looking going on three years?polkaudio SRS (rdo194 x 8)
Dodd ELP (separate power supply)
JC 1 blocks ( strapped )
Rega Apollo
MIT (speaker cables) Outlaw (ICs)
polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
B&K 505
Samsung LCD
VIP 622
HSU STF-2 -
No... but I am:)read-alot wrote:Damn, ya think he is still looking going on three years?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
ben62670 wrote:No... but I am:)
Well then let me give you some advice that I aquired early on this board.
"Don't believe anything you read and only half of what you see" or hear in this case.polkaudio SRS (rdo194 x 8)
Rega Apollo
B&K 505
Samsung LCD
VIP 622
HSU STF-2 -
True. YMMV. Didn't realize how old this post was.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Coaxial and Optical are both the same $hit it's all 111s and 000s...My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool: -
louthewiz wrote:Coaxial and Optical are both the same $hit it's all 111s and 000s...
I thought that only applied to digital connections?
Mike -
Optical is digital via light pulsesMikeC78 wrote:I thought that only applied to digital connections?
MikePlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Yes digital connections are via coaxial or optical connections,
the science in both applications are equal and while optical is by
light,
coaxial is by electrical both transfers of data are identical and the wiring has no audible difference.
Next thing members are going to say is that "burned in cables" make a difference.My gear,
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
optical
Just what is the bandwidth of DTS does anyone know, I know coax can do t3 level which is 45meg / 28 t1's or 672 phone lines. Seems to me 5.1 channel of anything should have no issue's moving by coax.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
It encodes audio by splitting it into 32 subbands, each with a bandwidth of 750 Hz - Wikipedia.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
louthewiz wrote:Yes digital connections are via coaxial or optical connections,
light,
I knew that!:o I keep thinking HDMI is the only digital connection that uses 000's and 111's.
Thanks for correcting me.
Mike -
I found this,
DTS 1.5mbit / sec or 754kbit / sec vs. Dolby Digital 448kbit / sec or 384kbit / sec. I guess theres actually 2 levels of decoding in both methods.
http://www.timefordvd.com/ref/dts.shtml
Again this should be no problem sending over coax. NONE.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Just a thought:
wire measured in resistance Ohm's
fiber optics measured for loss dB's
HUMMMMMMMMMMMMMMMMMMMMMMMM
engtazengtaz
digital is easily capable of transmitting a gig a second.engtaz wrote:Just a thought:
engtaz
If they can broadcast digital TV with sound many miles away....
If they can broadcast digital TV from earths orbit miles away...
Bandwidth isn't near being approached by currant media. Even with video included. Hi Def at that too.;)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
but I believe the sounds to be warmer for coax
die horse DIE ! THUMP! THUMP!:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables -
Are you saying there is no diffrence between coaxial and toslinks as far as sound goes?louthewiz wrote:Yes digital connections are via coaxial or optical connections,
light,
REGARDS SNOWWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
Do any of you watch your movies with the sound through the multichannel analog option?
I did this, actually by mistake, but found I liked the sound better than through the optical cable. Using the Anthem AVM 30 pre-pro I set the source to 6 channel with the THX Ultra 2 DSP overlay and preferred this to the optical option with the same DSP.
This was a new discovery for me as I only used the 6 channel option when I listened to multi channel music. I'm going to watch some more movies through this option just to make sure, but I think I might prefer this over both coax or optical digital formats.Main theater: Paradigm Studio 100's v4 L/R, CC690 Center, ADP 590 x4 Surrounds. Dual Outlaw LFM-EX-1's, Yamaha Aventage RX-A1010 as Processor, Anthem PVA-7 Amp
Secondary System: Polk RTi 6 L/R, CSi3, Center, FXi3 x4 Surrounds, Def-Tech Supercube II, Pioneer Elite VSX-23 Receiver -
The only difference is that opitcal has to go through two extra stages to change to light then back. The input going to the amplifier circuit for the light is the coax output and the output on the other side goes to the coax input. No doubt optical sounds "different" after going through these extra two conversions.
Why? What would the conversion add, or take away from the 1 and 0's? -
Not all 1's and 0's are repoduced exactly the same by every digital device. If they were then we'd all be buying cheap crap cuz it would sound the same as the expensive crap.
This subject is another that will never have an aswer that everyone agrees with. On MY system, with MY music, MY ears noticed an improvement over Toslink. I don't give a rats **** if anyone disagree's or not...you aren't doing the listening for me.
Quit arguing about it and go listen for yourselves and decide what you like or if you hear a difference.
We're done here. -
analog 5.1 and DD+ FTW!
FTW=For the win=the best."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I had a fellow Polkie over tonight and we wen back and forth with digital coax and optical from the same source. There was definitely a difference, coax seemed to sound fuller and more detailed to both of us.
It's not always about the 1's and 0's."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
i like optical better
I just ordered a "Premium Optical" cable from monoprice. When I get a change I'm going to test optical vs. coax since I can assign inputs on my pre/pro (coolest feature I never knew I needed). This will be my first experience with optical and I'll be interested if I can hear a difference.
I thought this horse Died!!!My gear,
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
