What speakers came with SL3000 tweeters?
engtaz
engtaz Posts: 7,669
edited March 2007 in Vintage Speakers
What speakers came with SL3000 tweeters? Floor, Bookshelf, Center.
Thanks,
engtaz
engtaz
Post edited by engtaz on
  • george daniel
    george daniel Posts: 12,096
    edited March 2007
    The "tl" versions that I'm familar with were all floorstanders, good question.
  • BobMcG
    BobMcG Posts: 1,585
    edited March 2007
    From what I remember the only speakers to come with the SL3000 tweeters in them were the 1990 1.2tl, 2.3tl & 3.1tl SDA-SRS speakers. (All floor standers of course.)
  • I-SIG
    I-SIG Posts: 2,243
    edited March 2007
    Don't forget about the RTA-11 & 15tl. Not sure if the RTA-8 had a tl version.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • engtaz
    engtaz Posts: 7,669
    edited March 2007
    Then what is the best match for center and other HT speakers?
    Thanks,
    engtaz
    engtaz
  • warlocks1
    warlocks1 Posts: 1,260
    edited March 2007
    The RTA 8 had a TL version. I believe every other one has been listed.
  • ben62670
    ben62670 Posts: 15,969
    edited March 2007
    TL and the RDO's work well together. You should come over for a listen:)
    Ben
  • engtaz
    engtaz Posts: 7,669
    edited March 2007
    Ben,
    You you keep teasing me. You and all your audio toys. Between you and George you both killing me. Ha Ha.
    Thanks for the invite both of you,
    engtaz
    engtaz
    F1nut Posts: 51,692
    edited March 2007
    The RTA 8TL used the SL2500.
  • engtaz
    engtaz Posts: 7,669
    edited March 2007
    What tweeters are the best sonic match or improvement? what are the price of polk RDO-198-1?
    Thanks engtaz
    engtaz
