Should I demo some Magnepan MG-1c's
candyliquor35m
candyliquor35m Posts: 2,267
edited March 2007 in 2 Channel Audio
Post edited by candyliquor35m on
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2007
    No and yes.
  • candyliquor35m
    edited March 2007
    dorokusai wrote:
    No and yes.
    Thanks. That's kind of what I was thinking after hearing tour2ma's 1.5's
  • madmax
    madmax Posts: 12,434
    edited March 2007
    dorokusai wrote:
    No and yes.
    The polk forum is always a good bet if you want a truely definitive answer. :D
    madmax
    Vinyl, the final frontier...
  • dkg999
    dkg999 Posts: 5,647
    edited March 2007
    I would wait for a pair of 1.5 or 1.6's. In my opinion the differences are pretty substantial. You should also watch for 2.5R's.
    DKG999
  • dorokusai
    edited March 2007
    I would suggest you stop the game and go big or don't go at all. I've hovered, listened or owned most of the lower models and it just doesnt make any sense to me. Magnepan is a c@ck tease.
  • TroyD
    TroyD Posts: 13,124
    edited March 2007
    Yup, w/ribbons...go big or go home.
    BDT
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited March 2007
    You'll spend as much with a small pair, buying a sub fast enough to keep up with them to fill out what they are missing - Martin Logan, Vandersteen, REL, etc etc....
    At the end of the day, you could have just bought bigger ribbons.
    Cheers,
    Russ
  • dkg999
    dkg999 Posts: 5,647
    edited March 2007
    I spent a bit of time with both the 1.6QR and the 3.6R's before I decided on the 1.6QR's. If you have the room, and the ability to place them properly, and the budget to buy good source gear, then the 3.6R's are the way to go. With mid-fi source gear, and limits on placement, the 1.6QR's will sound better than a compromised set of 3.6R's. I wanted the 3.6R's badly, and I will have a set some day, but with what I wanted to spend for source gear, and the imperfect room they have to fit in, the 1.6QR's were a much better choice.
    1.6QR with ceramic cryo'd fuses, Signal Cable Ultra Double Run speaker cables, Parasound HCA-1500 power amps - vertically bi-amped, Rogue 66 Magnum pre, Jolida 100 CDP, Signal Cable Analog Two IC's, SVS SB-12 sub.
    DKG999
  • RuSsMaN
    edited March 2007
    Excellent points. You've got to take into account Maggie's quasi-ribbon tech, and pure ribbon tech.
    Cheers,
    Russ
    tonyb Posts: 33,069
    edited March 2007
    I would be looking up some used Apogee's.Fairly reasonable on
    the used market.****,if you want ribbons and a bottom end,skunk
    up some Carvers.Maggies are too finicky for my blood.
  • RuSsMaN
    edited March 2007
    Apogee - better have a 1ohm stable amp.
    Carver Amazings - better have at least 1 horsepower per channel / continuous (375w).
    Maggies are finicky? ;)
    Cheers,
    Rooster
    tonyb Posts: 33,069
    edited March 2007
    Finicky as in hard to set up correctly.
    +1 on the amps too,but the sound is worth it.
    From what my ears remember,Apogee had some glorious tunes comeing out
    of them.Agree with the rest of you....go large or not at all.
