Which Sub PSW 450 or 404 ???
cthomas
cthomas Posts: 2
edited December 2002 in Speakers
I am in the market for a Sub, the problem is, I am not sure which one to get? PSW 450 or PSW 404.
My room is fairly small 17'x15' I mainly watch movies on my system, but I am planning to upgrade to DVD audio.
I have heard the 404 is much cleaner and has a better frequency response than the 450.
Has anyone compared the two? what do you think?
Thanks!
Main:RT800i
Center:CS400i
Surrounds:M3II
TV: 36" Sony Wega
DVD: Panasonic C-220
Reciever: Sony STR DB-930
Post edited by cthomas on
  • fireshoes
    fireshoes Posts: 3,212
    I prefer the sound of the PSW404 to the 450. It is just smoother and not nearly the port noise. The 450 may go louder though, I'm not sure.
  • faster100
    faster100 Posts: 6,124
    The 12" 450 i think might go lower but the 404 is more accurate i think, and tighter and not so boomy as the 450. for a sub i would get the 404, if you have a huge room get the 450 maybe
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • jdavy
    jdavy Posts: 380
    the 450 is an older model and may be cheeper to get. I like a 10" woofer myself. Get an old dual 10 instead of a 12
  • gplracer
    gplracer Posts: 36
    I do not mean to be negative. I have all Polk speakers and I live them, but I have a SVS sub. I think it is the best choice.
  • faster100
    The best choice maybe, But cost wise the most exspensive.. among the top 10 high dollar subs. depends also if you want everything to match and don't want a 4 foot cylinder in the corner
    : ) I would get one had the price been cheaper for an amped sub.
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
Howdy, Stranger!
